Old 10-13-2010, 12:35 PM
turboedgs is on a distinguished road
Design check needed
As stated in the topic, I just need a quick design check for the gear mesh system that I am planning on using for my Y axis sled. The image shows the intended air cylinders and the intended motion path for the meshing of the output pinion gear to the rack. The question is do you think this will work ok or would you recommend using a pivot type mesh system with only one air cylinder?
The reason for two air cylinders is that there isn’t much room for one air cylinder and the needed pivot travel without changing (widening) the sled which I would prefer not to do just yet.
This machine is intended to be dual purpose, performing both CNC mill and CNC plasma operations. I understand that the required force for meshing the gears doesn’t need to be too extreme for plasma however CNC milling will requires much more as the intended milling material will be 100% aluminum.
Any advice or recommendations based on experience are welcome.
I am still playing around with the design and considering other options as well regarding the Y axis. I plan in using rack and pinion for the X as it is 12’ long. I have designed in a pivoting mesh gear for the X axis using a slightly larger air cylinder. For the Y axis I am also considering going with a ball screw but I am concerned about whip/vibration at higher speeds (looking for 250-300 ipm max) The Z axis will be a ball screw as it will only have 12” max travel.
Old 10-15-2010, 03:58 PM
mlabruyere's Avatar
mlabruyere is on a distinguished road
Interesting design, why are you using "air cylinders" to provide the pressure on the pinion?
Wouldn't a pair 35lb springs attached as shown accomplish this without the air cylinder option?
Old 10-15-2010, 04:26 PM
thedave is on a distinguished road
If springs work, you could also use springs to "push" the same way that your air cylinders would. Also you could adjust the pressure on the springs by using a nut to increase the pressure. Good call on the spring idea.
Old 10-16-2010, 06:42 PM
Springs would defiantly work and are still and option. As stated both a compression or tension springs could work in this app. I may play with the compression spring idea with and adjustment screw. One advantage of the air cylinders is the ability to increase and decrease the force of the cylinder thus increasing/decreasing the mesh pressure. Right now the mesh force needed is an unknown.
Thanks for the input! Keep is coming.
Help needed to check my wiring before power up. gavztheouch Servo Motors and Drives 4 05-18-2009 10:52 AM
Check my *cough* logic - H-bridge design. samco General Electronics Discussion 47 04-17-2009 02:56 PM
New Machine Build- Sanity check design please... Rarius DIY-CNC Router Table Machines 20 03-12-2009 07:50 AM
please check my design. also screw position ? max_imum2000 Mechanical Calculations/Engineering Design 20 06-09-2006 04:57 PM
