| 48'' ? it seems that you are building a router. what size of rails you are using? jasminder singh
__________________ It is better to die for something than to live for nothing. |
| Your question is kind of hard to answer without seeing your plans for the machine? If you don't have plans I would begin to sketch the X and Y axis and try to picture the ways you can incorporate those actuators into the design to move your axis. As best as I can see from the pictures you have 2 actuators with ballscrews and slides included? I would try to leave them intact if possible and this will probably work well for the Y axis or gantry of the machine, but the other actuator may be difficult to implement for the X axis as the distance between the 2 rails is very narrow. You may be able to use a sturdy metal worktable mounted to the X actuator and possibly add some simple supports at the outer edges with bearings or if needed a couple more rails etc.
__________________ Regards, Wes |
| You said "fixed gantry" which implies "moving table". I don't think any of us can imagine a 48" moving table. You couldn't use a 1" wooden anything over 48" without too much sag unless you had some kind of bracing. If you meant moving gantry, 48" in one dimension can be done with a single rail/screw. If you are trying to do 48 x 48, you probably need two on the X, and one on the Y. Do you have 3 of them? |
| Remove one rail from each assembly. Mount the two assemblies to some sort of frame with the screws facing out, the one remaining linear rail facing in. Buy a piece of 80/20, the 3030 or 3060 probably, and connect the two carriages with that. Now take the two linear rails you removed and put them on the 80/20. Add another screw and you have an x and y axis. Then you just need a z. You could probably find something surplus on ebay to use if you didn't want to build one.
__________________ CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html |
| 3/8" V Groove CNC Router Linear Bearings w/ 36" RAILS! | karbunkle1952 | EBAY ADS | 0 | 10-03-2010 08:22 PM |
| Parker Linear Motor - IKO 35 series 69" linear Rails | S.A.C. | EBAY ADS | 1 | 07-28-2010 08:33 AM |
| 16mm open linear bushings on 5/8" rails. | IZen | Linear and Rotary Motion | 3 | 12-30-2009 02:31 PM |
| 65" linear rails | zigmart | EBAY ADS | 0 | 08-24-2009 07:31 PM |
| 1.5" unsupported linear rails. | magick_man | Linear and Rotary Motion | 7 | 01-11-2008 11:11 PM |
