Old 10-06-2010, 08:01 PM
tskguy is on a distinguished road
RC brushless spindle 90% complete......
Well I have been building this for the last month or so and finally thought I would show some pics to you'all and see what you think. I have most definitely stood on the shoulders of others during my design fase. Mostly Herbert(Thanks!!). My goal was for it to semi high speed, no more than 20,000 rpm and for it also to slow down and act as a spindle for milling as well. Rigidity and low vibration are also very important. Herbert's spindles have been completly direct drive (from the ones I have seen at least) and very high speed but I really liked his way of preloading the AC bearings. The housing is Stainless and so are a few other parts. Im also using aluminum, bronze and some delrin as well. Bearings are all super high precision angular contact bearings. Two in the front face to face and one in the rear in a floating cup with a wavy spring underneath. The preload is set by tightining the bolt on the end kinda sandwiching it all together. I hope that makes sense! As for the motor I have a 1200kv brushless close to 800watts that I plan on spinning at a max of 40,000 rpm witha 2 to 1 reduction. This spindle is going on my diy 12"x12" router. I have yet to fire it up, Im still machining the motor mount. And yes I plan on water cooling the motor!! Well anyway here are some pics.
Old 10-06-2010, 08:07 PM
diyengineer's Avatar
diyengineer is on a distinguished road
This is REALLY NICE!
What kind of power supply do you use to power the 800watt motor?
Old 10-06-2010, 08:42 PM
Well Im still trying to figure out what I will need for a power supply. But my first test will be with a 750 watt 12volt ps. That will only give me around 14400 rpm at the motor and 7200 at the spindle. But my needs arnt much greater than that so we will see. I am going to use a RC heli speed control that will allow me to hold specific RPM hopfully that will help out.
Glad you like it. I learned a bunch!!
Old 10-06-2010, 09:47 PM
Have you checked your run out yet by chance? Pretty good?
Do you use mach 3? Would you be able to hook up the controller somehow so mach could control it?
CNC4PC
There are some controllers located @ the link above. I hope to make my own in the future when my 2.2KW Chinese spindle dies. Just needed a lathe to make all the parts?
Old 10-06-2010, 09:50 PM
You should make a full build log tutorial of how it was done. You would sure help out a lot of people and i'm sure many people would be interested in making one! I would rather spend more money and make something i know will last then give money back to the chinese haha!
Old 10-06-2010, 10:40 PM
Hey,
Runout seems very good but I havent tested with a dial indicator yet. I plan on checking it after I mount it on the router. A lathe is a must for this kind a project. Every piece was machined on my crappy Harbor Frieght 7x10 lathe. Cutting stainless really SUCKS!!! I killed a bunch of carbid bits. Its also really hard keeping the run out 0 when using the lathe. A steady rest is also very important.
I do use mach3 (just the demo for now) and havent really thought about trying to controll the rpm. I do want at least controll spindle on or off though and to be honest I havent even gone down that road yet. I forsee problems with a rc brushless conroller though. In order to controll a brushless esc you need to use a servo tester. Its a device that emulates the pulses created by a rc reciever. Im sure it could be done but it would uncharted territory. For now just using a relay to controll the power supply will be good for me.
Saddly I always intend to document my builds but I always get cought up in the build. Then its to late if you havent taken pics the entire time.
Like I said before, none of this is an original idea. There are a few threads I have pointed out before that have every bit of info I used to build mine.
Look for any post from herbertkabi, that dude has really figured out the hard stuff.
Read this entire thread!!!
http://www.cnczone.com/forums/showth...p=94477&page=5
That thread is chocked full of good info. Also read as much as you can about Angular contact bearings. Before I started down this road I really had no idea how complicated mounting bearings can be.
Have fun, I will add more pics after I get this running a 100%
Old 10-07-2010, 08:23 AM
mactec54 is on a distinguished road
tskguy
Your spindle should be back to back for the lower bearings, normal spindle bearings are mounted this way
Great build
Mactec54
Old 10-07-2010, 08:41 AM
Shoot I meant to say DB or back to back! I just checked the spindle and I do have them facing the correct way .
Eric
Old 10-11-2010, 07:51 AM
dwalsh62 is on a distinguished road
Don't take this wrong but your wasting time on a spindle design that has limited versatility, why not design the spindle to support tool-change?
You're going through a lot of work and using a spindle shank for an ER11 (or ER20) collet.
I have already drawn some roughs on the requirements and it's not really that difficult once you understand the mechanics involved.
If you or anyone else is interested in going this route perhaps we can create a reasonably priced solution that increases the usefulness/versatility of the machine.
I'm developing a heavy-duty router/mill machine based on several different designs I've seen and I'm now getting to the point of machine assembly and will make the plans for the machine available.
It will cut steel (depending on spindle) and a tool changer is a nice feature that seems to be missing from all of the DIY designs.
Old 10-11-2010, 10:46 AM
Shoot I hope I didn't waste my time!
Honestly even though it would be extremely cool, I have no need for a tool changer. The design goal of my entire machine was to accurately drill tiny holes in brass. (microphone capsule to be exact)
I'm actually very lucky I built a machine that cuts aluminum at all. Steel is out of the question in its current form. Although maybe after my new spindle is mounted!
Right now I just have a crappy 1/4 inch router from Harbor freight. Its far from stiff enough for steel. I also only have 12 inches of XY travel so a tool changer would be restrict my cutting area. Depending on the design of coarse.
Lets see what you have planned though I'm sure its very cool!!
E
  #11   Ban this user!
Old 10-11-2010, 11:21 AM
Iron-Man's Avatar
Iron-Man is on a distinguished road
Servo Driver
Hey,
There are many articles on rc servo testers using the 555.
Here is a link and simple schematic: R/C Central Article: Servo Driver
Hope this helps,
Iron-Man
  #12   Ban this user!
Old 10-11-2010, 11:49 AM
I think he has done a awesome job. He had a problem and designed a spindle from scratch as the solution. Not many people can say they did it from scratch.
Can RC Brushless Motors be used as Spindle Motor ??? joprinz General Metal Working Machines 60 01-23-2011 05:21 AM
RC Brushless motor for spindle tmbg General Electronics Discussion 3 12-15-2009 02:20 AM
Brushless spindle motor Yint General Electronics Discussion 0 03-20-2007 11:36 AM
Brushless spindle drive using Stevie Servo Motors and Drives 9 02-03-2006 08:57 PM
brushless motor as spindle? limbo DIY-CNC Router Table Machines 24 03-02-2005 01:01 AM
