Old 10-02-2010, 09:16 AM
coloradonewbie is on a distinguished road
Need a plastic electronics enclosure cheap!
I've been looking at all the really cool enclosures that are created by you folks on the Zone.
Amazing to say the least. I just need a place to get a plastic box or panel, semi rigid so it doesn't flex too much.
I'm just mounting a 24VDC/5A flat power supply and a 3 axis Toshiba TB6560 stepper controller in it.
I have a power switch and an e-stop I'd like to mount as well. The original Xylotex box I have is little small
for good air flow in there.
Any ideas on where to get one locally would be great. Online is ok too.
If I can't find anything I like that's cheap, I'll probably just build a wood one
with a clear plexi door or something.
Thanks in advance,
Colorado Newbie
Old 10-02-2010, 11:37 AM
quazga's Avatar
quazga is on a distinguished road
Take a look at these. Not pretty, but they'd keep the metal chips out.
Shop Storage : Totes & Baskets at Lowes.com
Old 10-02-2010, 11:49 AM
Iron-Man's Avatar
Iron-Man is on a distinguished road
What size do you need?
I found some excellent enclosures on ebay [Hoffman Cases]. Most are metal and fiberglass, but make a professional set-up.
HOFFMAN Enclosure Box - 8" x 8" x 4" - eBay (item 180564198418 end time Oct-21-10 07:37:33 PDT)
Hope this helps,
Iron-Man
Old 10-02-2010, 01:26 PM
toughtool is on a distinguished road
You can get a 12"X12"X6" Gray plastic box (NEMA type 6P) from here for about $33.00. They have smaller ones too.
Carlon 12 In. x 12 In. x 6 In., Gray, Junction Box - E989R-UPC at The Home Depot
Joe
Old 10-02-2010, 01:49 PM
jsheerin's Avatar
jsheerin is on a distinguished road
How about plastic storage containers? Lots of sizes, various types of sealing, cheap and easily available. Some of them might need a bit of reinforcement.
CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
Old 10-02-2010, 03:57 PM
Gold Member
RomanLini is on a distinguished road
I would be a little wary about the safety of plastic storage containers. Usually they are polypropylene and are brittle, ie trip over and fall on one and it can shatter and fry you with live wires, they can also crack and fail due to drilling even if the holes initially look ok when you drilled them.
They also tend to degrade quickly (getting even more brittle) if they get any exposure to sunlight etc.
Old 10-02-2010, 05:46 PM
Regnar's Avatar
Regnar is on a distinguished road
For a few dollars more you can pick up a steel enclosure and all your other needs from Factory Mation.
Here is a link NEMA 1 Continuous Hinge
And a picture of mine that all but a few parts where sourced from
ID:	116023   Click image for larger version
ID:	116024   Click image for larger version
Old 10-02-2010, 08:08 PM
doorknob's Avatar
doorknob is on a distinguished road
How do you route the PC cable, stepper motor cables, AC supply cable, and the like? Do you punch or drill holes in the enclosure and mount connectors, or something else?
Old 10-02-2010, 08:24 PM
quazga's Avatar
Smile
Polypropylene is one of the least brittle plastics known to man. They make what is known as living hinges out of it that can be flexed for millions of cycles before failure.
It's true that it can degrade in ultraviolet light, as with most plastics that don't contain UV inhibitors, but that takes time, at least a few months before the material properties change enough to be significantly noticeable.
Your comment sounds as though it is based on experience. So the only thing I can think is either the material you had was sitting in the sun for a year or more, or the polymer was manufactured with very low quality methods and materials.
Then again, you may have experienced these properties with a plastic that was something other than polypropylene or polyethylene.
Old 10-02-2010, 08:53 PM
Regnar's Avatar
You could use connectors but it will get expensive quickly. I use cord grips and run the wires to where they need to go.
Cord Grips
  #11   Ban this user!
Old 10-02-2010, 09:19 PM
doorknob's Avatar
Interesting...
I had never before heard of "cord grips" - but I guess that they make sense if you need to have environmental isolation (or if you want to save the cost of connectors)...
Old 10-03-2010, 05:33 PM
Gold Member
My opinion was based on experience! I have used small PP containers for bulk parts storage for about 15 years, it is very brittle and most of the well-used containers have needed replacing due to cracking and failure.
I have also used larger PP containers for tool storage and some have also cracked and failed. One left in the australian sun for only a couple of months failed terribly with change in colour and literally fell apart. Storage containers (as specifically mentioned by jsheerin "cheap and easily available") from the house goods stores are almost always PP and are BRITTLE. Stomp on one if you don't believe me, it will explode into shards.
As for living hinges, that would be polyethylene or a styrene (like ABS) as PP is generally unsuitable.
Electronics Enclosure + VFD rwskinner Automation Technology Products 0 01-14-2010 08:49 PM
Electronics Enclosure Build BobWarfield Industrial Hobbies (Support forum) 74 04-08-2009 09:37 AM
Electrical/Electronics Enclosure audioandy1762 DIY-CNC Router Table Machines 0 02-27-2007 06:32 AM
Not sure what to do about electronics enclosure phantomcow2 Benchtop Machines 18 02-08-2007 10:29 AM
Electronics Enclosure Box JavaDog General Electronics Discussion 9 04-21-2005 08:00 PM
