I'm not finding this through searching. How do you assemble a T-slot table so that it's flat and rigid? Any recommendations for sizes of extrusion for a 2' x 4' router table? |
![]() I was very careful about cutting the 4 cross pieces to make sure the were all the same length, then just bolted it all up. It was flat, square and very rigid.
__________________ Pencilneck blah blah blah http://tinyurl.com/22lqgvv <=== My CNC Mill build thread |
| Use a fly cutter, or just a big straight cutter and surface it with the router. Look on the Fineline or cncrouterparts website for a 2 x 3 plan that uses 15 series extrusions for the bed. I have a 4 x 4 from Fineline. It uses 30 series extrusions for the outer frame, and 15 series for the bed support. See my thread at http://www.cnczone.com/forums/showth...?postid=826384 for pictures |
| Well, there is the aluminum surface over the whole table, with slots cut in it, for which I don't have a suggestion. Then there is T-Track on MDF. That's what I'm in the middle of doing. I am putting a 3/4" MDF board down covering the whole table. I'm mounting T Track to that, with about 8" spacing. Then I'm putting down 3/4" MDF strips between the tracks. The T Track I'm using is from Orange Aluminum (http://www.orangealuminum.com/t-track/t-track.html). It's only 1/4" track, not the 5/16" that you often see. However, at $7.12 for 48" length, it's VERY cost effective. |
| I saw an interesting t slot arrangement on a 7 x 12 mini lathe I think by Jeff F. You could use the same principle. He started with a flat table and then mounted a number cast iron strips on top, these strips had rabbits on either side, that faced down and the strips where placed apart forming a t slot. I will try to find a link to this and post it. |
__________________ ...He who makes no mistakes makes nothing! ... Tom |
#10
#11
| Ok maybe im just a red neck, but if the BASE table and bearings are good. Just run a mill across the entire surface of the table cutting a few.001 out off it. When you get a completely cuts on the entire table it is a flat tablet. Let your mill do the work. or you can do like i do use fixtures and make mill them flat. then your z is flat from all points of reference. bob |
| Best way to make a deep slot. Drill Chain? | Kingjamez | General Metalwork Discussion | 13 | 09-06-2010 12:52 AM |
| New Machine Build- How do you get a table FLAT, TRUE & SQUARE? | WSS | CNC Plasma and Waterjet Machines | 25 | 07-28-2009 11:24 PM |
| 100% flat table for flat bed lamination | Bernhardsen | Printing, Scanners, Vinyl cutting and Plotters | 4 | 08-24-2008 08:31 AM |
| With a reference flat, how does a machine bed longer than the ref get scraped true ? | bobJandal | Mechanical Calculations/Engineering Design | 13 | 09-18-2006 01:03 PM |
| anyone make their own t-slot linear bearings? | rkremser | 80/20, TSLOTS and other Aluminum Framing Systems | 7 | 06-09-2005 01:03 PM |
