Old 09-27-2010, 10:32 AM
DonFrambach is on a distinguished road
New DYI Fixed Gantry Router Build
I'm about to start building a small fixed gantry router. I plan to make complex carvings in wood (and hopefully aluminum) using models prepared by Vectric Aspire.
I've attached drawings of my anticipated build. Comments (especially those pointing out design flaws will be greatly appreciated). I plan to make most of the components from 8020 extrusions and connectors. A small amount of steel plate will be used. I plan to use rails and blocks for the X axis obtained from Glacern. The Y and Z sliders will be made using components from CNCRouterParts.com.
I will add corner gussets and plates for rigidity that are not shown in the drawings.
ID:	115617   Click image for larger version
ID:	115618   Click image for larger version
ID:	115619   Click image for larger version
Last edited by DonFrambach; 09-27-2010 at 10:44 AM. Reason: added statement re gussets and plates
Old 09-27-2010, 11:55 PM
Another drawing. The X-axis lengthened a little. More details added. Did not add plates to the drawing because they would obsure construction details.
Comments?
Old 09-30-2010, 10:35 AM
DeadTom is on a distinguished road
Looks good so far, start collecting the needed parts and keep the pictures coming.
DT
Old 10-15-2010, 12:34 AM
Construction has begun! I expect it to take some time. Comments will be greatly appreciated.
Old 10-15-2010, 01:58 AM
Gold Member
RomanLini is on a distinguished road
Looks nice! I saw your orig cad drawings before when you posted the thread.
Are you going with the design in post #2? If so it might be best to turn the 2 inside base cross rails to vertical, to give 4 support places for the rails (not just the 2 rail ends).
I also think it would be good to add a base plate either above or below the base area to reduce flex there, my preference would be above as it will also be cleaner for stopping chips that would fall down and fill up your base structure.
And one thing that's always worth thinking about is to re-examine how much vertical travel you actually need. With a moving table build only the Z axis is mounted on another axis so its the only axis with multiplied slop, so by reducing Z travel and spacing the Z bearing further apart vertically, you increase total ridgidity a lot. On my littl emoving table machine i limited the Z travel to 60mm and the gantry clearance to 60mm (for better rigidity) and have never regretted it.
Old 10-17-2010, 09:18 PM
Some more progress. Removed gantry (for now). Added corner braces to base. Also assembled base with longer screws (not shown were 5/8" now 1"). Added support for x-axis. One rail placed on support. Not screwed down yet.
ID:	117056   Click image for larger version
Old 10-17-2010, 09:24 PM
Assembled Z axis per plans from CNCRouterParts.com. Also got Mach 3 running on an old PC and connected to a Gecko G540 and 3 steppers. Works real well. Under no load, there is no measureable backlash with my cheap Grizzley dial indicator. Electronics still need to be encased. Thinking about a Smooth Stepper too.
Will probably reduce Z travel in future. Without reducing travel, the assembly can be shortened by about 2 inches.
ID:	117058   Click image for larger version
Name:	open electronics.jpg‎
Old 10-18-2010, 09:40 AM
Your making good progress Don; what size are your steppers?
Tom
Old 10-18-2010, 02:37 PM
Tom
NEMA 23, 380 oz-in steppers purchased from CNCRouterParts.com
Don
Old 10-19-2010, 09:35 AM
Don,
I am running the a HobbyCNC Pro board with 200 oz-in steppers, they are pushing around a modified JGRO (mdf=heavy) machine with a Sears Craftsman 2.5hp router. Works pretty darn good, could be just a little faster though as I am running single start 5/8" 11tpi all-thread on all of my axis. I can run at a respectable 30-40ipm, I can push it but I don't want to break anything until I finish my upcoming all-metal machine.
So, your steppers will probably drive your bits and/or spindle right through the bottom of your table so be careful , jk.
But you do have alot of power for such a small cutting area.......awesome.
Tom
  #11   Ban this user!
Old 10-21-2010, 08:42 PM
cncbob is on a distinguished road
I like the look of your machine, seems very sturdy. One day I think I may build one out of extrusions as well.
  #12   Ban this user!
Old 10-23-2010, 12:13 PM
A little more progress. Finished mounting the X-axis rails to their supports. Beginning to add support plates. My teasing wife keeps telling me that I didn't have enough tinker toys when I was a kid and I'm making up for that now. I'm a little concerned that the gantry may be too tall as pointed out by RomanLini. Some photos:
ID:	117463   Click image for larger version
ID:	117464   Click image for larger version
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
andtfoot
New Machine Build- Fixed gantry router KTP DIY-CNC Router Table Machines 25 04-17-2011 05:44 PM
Moving table fixed gantry build judleroy DIY-CNC Router Table Machines 48 12-14-2010 10:11 PM
Will Build a Moving Gantry ROUTER-comments appreciated. CNCfun&games CNC Wood Router Project Log 29 11-21-2010 12:51 PM
Want to build stout gantry CNC router Jr's Farm DIY-CNC Router Table Machines 7 10-23-2009 02:37 PM
Aussie gantry router build number 4 Rodm1954 CNC Wood Router Project Log 21 08-01-2007 02:43 PM
