Old 09-27-2010, 10:15 AM
basskitcase is on a distinguished road
Stall Sensor for Steppers?
I have run into a few instances with my machine where i had a motor stall that could have been disasterous if i had not been right by the machine (caused the router to plunge collet deep into the work).
Is anyone familiar with a way to monitor the motor current of a stepper (unipolar or bipolar) to cut the machine off in case of a detected stall?
I was wondreing about using a low amperage circuit breaker in series with the motor windings (assumption: current spikes when motor stall?) tied into a relay that feeds back into the limit switch connections?
Old 09-27-2010, 01:17 PM
tpworks's Avatar
tpworks is on a distinguished road
encoders
...He who makes no mistakes makes nothing! ...
Tom
Old 09-27-2010, 01:26 PM
CarveOne is on a distinguished road
You mean something like this?
Been there, done that....
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 09-27-2010, 09:12 PM
ger21's Avatar
http://rogersmachine.net/encoderinterface.html
But, it's cheaper and easier to just run them within their capabilities. They only stall if you try to go faster than they're capable of.
Old 09-27-2010, 10:37 PM
neilw20's Avatar
neilw20 is on a distinguished road
Limit the speed
Why do want to push the speed too close to the limits?
Use bigger motors or back off.
Cutting too much air at high speed? Optimize tool cutting paths.
Run within the proper limits steppers NEVER stall.
For reliability I have reduced 2500mm/min to 1500, and with expensive tooling and material have never had a problem in over 1000 hours, but might have saved 10 hours and lost $$$$$s of time and expensive materials. 80000++ parts and no stuffups, all on a syil SX3.
If you want a rocket ship use a servo based system and pay the money.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 09-28-2010, 10:22 AM
I don't want to push the steppers faster than they are capable of, but it would be nice to have the extra peice of mind of stall protection, as you never know when something might go wrong. Something mechanically could fail (timing belt break, screw vibrate loose, etc) and then you could stall the machine, even if you are not running the steppers faster than they are normally capable of. I don't want to overengineer, but I like safeguards just in case. I had thought about encoders but was hoping for something a little less pricy. Does anyone know if my assumption about power spiking when steppers stall is wrong?
Old 09-28-2010, 07:26 PM
cyclestart is on a distinguished road
Don't know, interesting idea.
Digikey has some nice rotary encoders for ~$30, maybe more than you want to spend. A resourceful electronics guy can probably salvage something functional for $0. Being neither resourceful or electron literate I paid Digikey. An encoder reading directly off the screw (not the motor) would cover +90% of the common failures. That said, if there's a cheaper way than encoders let's hear it
edit/ well +90% of the mechanical failures. The nut behind the wheel is usually the weak link
Anyone who says "It only goes together one way" has no imagination.
Old 09-28-2010, 07:42 PM
neilw20's Avatar
Don't rely on electroinics to protect you.
Do the protection mechanically. eg belt.
Sense failure, by belt tension or similar
It is emergency stop dropping out a safety relay (you should already have).
Keep the protection SIMPLE. Never rely on anything electronic.
Old 09-29-2010, 06:14 AM
So the encoders themselves seem reasonable, but don't i need an additional interface board, or can I tie them directly into Mach3 somehow?
Old 09-29-2010, 07:41 AM
Sounds like a question for Mach support ?
Here's something from the guy at candcnc
http://www.cnczone.com/forums/showpo...41&postcount=4
He suggests it's possible(?) although you might want use a relatively low count encoder if counting in software. The CUI amt encoders can be set within a range of counts/rev.
Old 09-29-2010, 09:47 AM
ger21's Avatar
You can wire them to a parallel port. But, if you want them to stop your machine, you'll need to write a plugin or macropump to do it.
The encoder interface I linked comes with a plugin to stop the machine when it loses position.
  #12   Ban this user!
Old 09-30-2010, 03:54 PM
Drools's Avatar
Drools is on a distinguished road
This is more what I was looking at when I asked about encoders on steppers a while ago. I to would just like to stop my machine if a certain (x) resolution threshold has been reached or compromised. I’m not looking at having Mach3 control the steppers. I also was thinking about having some sort of sensor on the work piece to tell me if it has moved. I do a lot of PCB/Plastic routing where I hold the material down with double sided tape so it would be nice to know if the work piece has moved even slightly.
help with x stall fre2fall5 DIY-CNC Router Table Machines 10 05-09-2008 04:06 PM
Steppers stall at low speed spiral72 CNCzone Club House 4 01-23-2008 01:49 PM
Stepper stall ez-cnc.com Stepper Motors and Drives 7 12-23-2006 09:10 PM
Need help with stepper stall orbyog Stepper Motors and Drives 10 03-19-2006 03:54 PM
stall detection mechanicer General Electronics Discussion 24 01-23-2006 03:08 AM
