Old 09-24-2010, 05:33 PM
msimpson99's Avatar
msimpson99 is on a distinguished road
offset question
OK I find the edge of my piece and zero the cords.
After designing a piece in Cut2D or other programs when I run my gcode My offset seems to be slightly off.
I am using the elctrical method of using the bit to touch a piece of angle aluminum. I do rotate the bit so the long edge makes contact.
What I had been doing was subracting half the diameter of the bit but I am still off. Should I move the bit to the outside of the material and zero.
What I am looking for when zeroed what is the programs like Cut2D, Cut3D , VcarvPro looking for so that my cuts are referenced properly?
FYI both the x and y seem to be off the same currently its like .125 off on both axis.
Old 09-24-2010, 09:00 PM
Cmailco's Avatar
Cmailco is on a distinguished road
Question
Not sure I understand that method. What diameter is the tool? Are you sure you're offsetting in the right direction?
Regards,
Chuck
The Manufacturing Reliquary
http://cmailco.wordpress.com/
Old 09-24-2010, 09:17 PM
msimpson99's Avatar
Contact probe would probably better explain it.
Old 09-24-2010, 10:31 PM
msimpson99's Avatar
This is what I am doing and it seems to be working. I think my original problem was I had a bit that has a chip in the end and that was messing up my original edge test.
HEre is my procedure
1. Orient the outermost tip of the bit tword the edge I am testing.
2. place aluminump plate againts edge and run edge test
3. Once probeing is complete zero that axis
4. Repeat for other axis
5. move x and y so that center of bit is on the edge. IE for a 1/4" bit I move .125
6. Zero both axis.
This gets me pretty close but witiin .005 or so of my edge and seems to work. However its subjective as I have to rotate the bit.
Would it be better to add a external probe to the router holder?
Old 09-24-2010, 10:40 PM
ViperTX is on a distinguished road
msimpson99,
I'm facing the same problem, but I'm using MeshCAM. In MeshCAM I had to "lock the stock" dimensions because the software was adding an offset for some reason.
And when I zero like you do, I move out the diameter of the bit from the edge and not just 1/2 the diameter as you're doing.
Hope that helps.
Paul
Old 09-24-2010, 10:52 PM
tpworks's Avatar
tpworks is on a distinguished road
instead of moving the bit after you zero the edge, click on the axis DRO an type the offset in and hit enter. for example for .25" bit enter -.125 and enter, offset is set, do the same for the other axis and set your z height I use a 1/2" precision block and raise the bit until I can slide it under, type .5 in the z DRO and hit enter, then click go to Z .
...He who makes no mistakes makes nothing! ...
Tom
Question about part offset, G54-59 Sticky Racing G-Code Programing 6 12-05-2007 09:46 PM
Work Offset Question Cartierusm Mach Software (ArtSoft software) 17 11-29-2007 03:50 PM
Offset question Chris64 SheetCam 2 09-09-2007 04:01 PM
Offset Question John H General Metalwork Discussion 7 09-22-2006 10:03 PM
tool offset question WarrenW SheetCam 7 04-29-2006 01:43 AM
