Old 09-21-2010, 12:08 PM
austin.mn is on a distinguished road
cool way to make timing pulleys
I stumbled across this today and thought others here would appreciate it.
http://reprap.org/wiki/Adesina_-_A_W...endel_RepStrap
buying pulleys can get expensive. I often find myself just short a pulley or two to make a project. So I think I am going to order some mold making supplies so I can cast some spares of sizes I already have, and also might use this method to make some odd sizes. One could also use this method to make pulleys with odd shapes. Which could be handy for those off the wall ideas one may have.
Need Help!- Timing pulleys native34 Bridgeport and Hardinge Mills 3 08-28-2009 07:18 PM
i want to cut timing pulleys , so help !! max_imum2000 General Metalwork Discussion 18 08-08-2008 12:16 PM
Timing belt and pulleys samakthachai Laser Engraving & Cutting Machines 8 10-24-2007 11:31 PM
Timing Belts and Pulleys Gorillakilla Mechanical Calculations/Engineering Design 20 03-12-2006 11:19 AM
Timing Pulleys h_2_o Benchtop Machines 7 02-02-2005 10:26 PM
