Hi all, I am building a new cnc router with a table cutting size of 42" x 30". I am planning on using 80/20 extrusion, and I am going to use some linear rails, either Hiwin or THK. Do any of you see a performance difference between 15mm rails and 20mm rails? just for clarification, the rail widths are 15mm and 20mm, the heights are the same on both at 15mm. |
| What kind of rail? this is more important than size. Four point HSR can hold load in all direction, SR not. A bigger rail can hold higher load, wider rail can hold higher load in some direction, check manufacturer specs they are quite detailled about this. |
| woodworker2 For long rails you want them at least 20mm/25mm wide, as the 15mm are harder to get straight in long lengths,unless you have a machined surface with a shoulder to put them on Mounting on extrusion does not give the 15mm rail much support,3.5mm each side of the slot is not enough
__________________ Mactec54 |
| 20mm rails and bearings | Ed Williams | EBAY ADS | 0 | 10-27-2009 10:34 PM |
| 15mm ally plate | stk2008 | DIY-CNC Router Table Machines | 3 | 10-27-2009 12:42 PM |
| 16mm vs. 20mm supported linear rails... | WilliamD | DIY-CNC Router Table Machines | 4 | 12-19-2008 05:37 PM |
| Four Carriages on Two 15mm Rails or a Single Carriage on a Single 45mm Rail ??? | joprinz | Linear and Rotary Motion | 12 | 10-07-2008 06:08 AM |
| Why do some people say you need 20mm rails??? | Mr.Nerd | DIY-CNC Router Table Machines | 6 | 06-28-2006 07:05 PM |
