Old 09-20-2010, 02:51 AM
Darian S is on a distinguished road
Smile Need Help with Spindle alignment!
Hi, Looking for help please with spindle alignment as i think it is the cause of the following problem, Example: when cutting a circle (anyshape for that matter) with every pass im removing 4mm of material which leaves really noticebale lines in my work almost .5 to 1mm of a differance on each pass but only on the rear sides of my shapes the -x and -y so to speak?
I have tried differant cutters speeds and feeds and still the same (maybe less burrs some times)
Any ideas welcome, Thanks
See pics attached as they may explain it better than me, both pics are of the same part just differant sides.
ID:	114987   Click image for larger version
Old 09-20-2010, 04:30 AM
doorknob's Avatar
doorknob is on a distinguished road
This is just a guess, but the problem may be related to the reversal of the direction of motion of one of the axes - if so, then it might be due to uneven backlash or binding on one of the axes, perhaps also including missing one or more stepper steps as a result.
Old 09-21-2010, 03:57 AM
Hi Thanks for your advise, what do you mean by missing one or more stepper steps?.
Cheers
Old 09-21-2010, 08:32 AM
doorknob's Avatar
Your CNC router table probably has one stepper motor that moves it in the X direction and another stepper motor that moves it in the Y direction.
A stepper motor rotates the motor shaft a fraction of a turn (a "step") each time your computer sends a step command to it. Depending on the design of the motors and driver electronics used by the table, it may take anywhere from a couple hundred to a few thousand steps to rotate the motor shaft by one complete turn. Depending on the type of mechanical linkage between the motor shaft and the table, to move the table one inch may require ten or more complete turns of the motor shaft.
If there is any mechanical binding of the moving parts of the table, or too large a weight load to be moved compared with the power rating of the stepper motors, or if the motors are commanded to step more quickly than they are able to respond, then it is possible that the motor will sometimes "lose a step", that is, the motor will not be able to rotate by a step when it has been commanded to do so.
In such a situation, the computer will not know that the motor has lost one or more steps. Consequently, the actual location of the cutting tool on the workpiece will be different from the location where the computer thinks the tool is working, and the pattern cut into the workpiece will not be identical to the pattern that the computer commanded it to cut.
Old 09-21-2010, 05:43 PM
Hi Cheers for reply
I have two motors on my x axis as they are facing each other i have wired one the opposite to the other so they both drive in the same direction, i have looked futher into your advise and found that Mach3 will drive another slave axis (x)in my case do you suggest this is a better way to drive two motors? i guess it would be as then the both receive there on steps right?
More ideas welcome esp on how to set up a slave axis.
Thanks for your help
D
Old 09-21-2010, 06:02 PM
doorknob's Avatar
I do not have direct experience with Mach3 - perhaps someone who does can chime in here.
As for running both X-axis motors in parallel vs. using a "slave" axis drive, there's not much that I can suggest - if both motors are identical, then it should be OK to wire them up in parallel, as long as doing so does not exceed your driver electronics' current ratings. If you go to a "slave" axis drive configuration, then I expect that you will need to add a separate drive circuit for that motor.
Unless you are exceeding the X-axis driver's current rating, I'm not sure that I'd look to that as the most likely cause of your problems. Rather, I'd guess that backlash or misalignment of driving forces between the two X-axis drives, or binding in the X axis travel, or even a loose drive coupling might be a more fruitful thing to investigate, particularly in the region where reversal of the direction of motion takes place.
Having said that, I'm hardly an expert in these matters, and there are many more capable folks here who may be able to give you better advice...
Old 09-21-2010, 06:03 PM
ger21's Avatar
Do you have two motors on opposite ends of a single screw?
Old 09-21-2010, 06:12 PM
Hi
The two x motors are on ether side on the gantry, they both have there on stepper motor drivers, i have paralled the the feed to both of these units but reveresed the direction on one of them, i have since figured out how to make a slave axis of the X output in Mach3. I will reconfigure the machine toinght as post results thanks very much
D
Old 09-21-2010, 06:20 PM
Hi Also i might add that both stepper motors have there own small gear box so speak in order to get more tourqe i guess, on both sides of the machine is a linear rail that the gantry sits on this gets drive from a rack and pinion setup.
Old 09-21-2010, 06:22 PM
stk2008 is on a distinguished road
Hi am I reading this right you have two stepper motors on one on each end of a lead screw?.
If so is your machine that big you need two motors?.
You probably have one motor setup wrong or slipping?.
Got any pics of the machine?.
  #11   Ban this user!
Old 09-21-2010, 06:34 PM
Hi
Sorry if i havent made it very clear,
two motors drive the x axis
two linear rails down ether side of the machine
no lead srews but instead a rack drive (toothed rail) down ether side of the machibe.
The motors are on ether side of the gantry and a pinion from the gear box makes contact with the rack and thats how it moves.
The machine is 1200/2400 bed wise and x,y,z and i have a c10 breakout board driving the stepper motor controllers.
Will take pics and post
Cheers
  #12   Ban this user!
Old 09-21-2010, 09:28 PM
Aryantes is on a distinguished road
Make sure your table is perfectly perpendicular to your spindle.
I had this same issue and still do as I haven't found the perfect way to align my spindle.
I had chatter marks and chatter sounds but only on half of the circle.
The best thing to do would be to get a planing bit and surface your entire spoilboard if you think that the spindle is not aligned perfectly.
I haven't tried this yet but it should work for me but I am in the process of switching out a few parts.
Spindle Alignment forrest39 Benchtop Machines 9 08-03-2010 05:36 PM
Toolchanger/Spindle Alignment lovell110 Haas Mills 3 06-14-2007 06:26 PM
Lathe spindle alignment dahui Shopmaster/Shoptask 8 04-06-2007 04:38 PM
Spindle is out of Alignment Crashmaster General Metal Working Machines 2 04-05-2007 10:32 AM
Laser spindle alignment? cgallery DIY-CNC Router Table Machines 4 09-25-2006 12:15 PM
