How to calibrate A Axis to get the right angle using Mach3 Settings menu Steps Per Unit button? Im using gear reduction and I want to get the perfect angle rotation when I command 45 90 180 degrees etc. Also if I plan to make the stepper motor as Tangenital Knife how can I get the steps per unit? |
| Try setting it to steps per degree of rotation.
stepper probably 200 steps per turn. From gear ratio work out how many stepper turns for 360 degrees. Multiply that by 200 above. Then divide by 360, for steps per degree.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. Last edited by neilw20; 09-18-2010 at 10:02 AM. Reason: typo |
| Use a rough estimate of steps to obtain one complete revolution using something which is indicatable such as a peg or a straight edge. When you can true a surface and command it to go 360deg's and it comes back to exact same point you have exactly what you need.
__________________ Don IH v-3 early model owner |
| Tags |
| a axis, calibrate, tangenital |
| Axis Calibration | davidshearer | Tree | 7 | 03-10-2010 09:47 AM |
| calibration of x and y axis | japco43 | Calibration & Measurement | 5 | 01-26-2010 04:12 PM |
| Need Help!- Axis calibration? | saabaero | Tormach PCNC | 16 | 06-23-2009 08:54 AM |
| Need Help!- x and y axis calibration | japco43 | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 04-27-2009 02:07 PM |
| Mach 2 Axis calibration | mikie | Mach Software (ArtSoft software) | 4 | 08-17-2005 07:19 AM |
