Old 09-12-2010, 09:04 PM
j2sip is on a distinguished road
Help with new design
I've been toying with this design for weeks now. It uses homemade V-Bearings with the V part almost 1/4" deep.
The 2nd picture shows how they are arranged for the moving table. The angle bars are 3/16 aluminum. I know several CNC router design uses V bearings where they ride on rails vERTICAlly. Mine are horizontal held only by force, no preload. My question is will they be able to keep the table from lifting or falling? Or should I grind my own rail ala mechmate so that the V bearings will ride on proper V rails? Help will be much appreciated.
Thanks!
Jordan
Old 09-14-2010, 03:40 AM
diyengineer's Avatar
diyengineer is on a distinguished road
I think well bring the conversation over here haha! I didn't know you had a build log going! Opps!
Upload some more pictures and ill be more then glad to help you with what i can. =)
Old 09-14-2010, 03:59 AM
Blame me. I have completely forgotten about this post. Ok I'll update my drawings and study more about other's designs. Your machine is...scary. Nice drawings and renderings! Without a spify PC those would take weeks to render!
Old 09-14-2010, 06:32 AM
CarveOne is on a distinguished road
You will need some slotted holes on one side of the table for the V rollers so that you can keep enough pressure against the angle rails to prevent the table from gradually dropping downward as the rail and rollers wear in.
I would even recommend some sort of screw adjustment (maybe with tension springs) for the rollers on one side of the table to make it easier to adjust. As the wear increases you may even see the table move over a little in the opposite direction to the cutter travel if the looseness gets worse. Not by much, but the rollers need to stay in contact with the edges of the rails at all times or there will be some small amount of looseness. If you are engraving metal plates, you may notice things like sideways movement that distorts text. The letter "O" won't be the correct shape.
How bad these effects are all depends on what you intend to do with this machine. Something to plan ahead for.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 09-14-2010, 03:23 PM
That's 2 for 2 on the slotted bearing adjustments!
CarveOne
Old 09-14-2010, 07:50 PM
ger21's Avatar
An eccentric bushing is better than a slot, as it's easier to adjust. There's some pics on the Mechmate forum of home made ones. Basically a bolt with a hole drilled through slightly off center.
Old 09-14-2010, 07:57 PM
Thumbs up
Soo thats what they are called! Thanks Ger21! Everyone one of my bearings on my big machine has one of those suckers. It scares the **** out of me when it comes time to dial it all in and get it all level. Should be fun.. =I
But yes for adjust-ability they are awesome, once its dialed in that is..
New Machine Build- New design - Quick question about my design guerd87 DIY-CNC Router Table Machines 1 02-14-2010 12:35 PM
New Machine Design book from Alexander Slocum (of Precision Machine Design) toastydeath General Metal Working Machines 10 11-25-2009 10:37 AM
design grad project: new breed of CNC design, need input nicanor76 DIY-CNC Router Table Machines 11 09-22-2009 04:53 PM
Finding Engineering Design Software For Automatic Machine Design hellokitty General CAM Discussion 0 01-06-2008 12:39 AM
