| Most round knobs with two set screws are made to fit 1/4" shafts like are used on Nema23 step motors. By using round electronics utility knobs you can leave them on the shafts. If you forget to take a crank handle off and then do a fast jog you may cause some damage to the motor. On the other hand, the crank handle probably doesn't leave set screw marks on the motor shafts. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| Yeah a drill press a thread tap and a scroll saw!
__________________ Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3 |
| If you want a large knob, you can find instructions and gcode here on the Solsylva site. It's a knob for a hold down clamp, but it can be used with some modification to the center hole. I just use 1" diameter plastic knobs and leave them on the motors. They can be cut from just about anything that is solid enough. I suppose that Nylon or Delrin dowels can be cut to length, center drilled, then possibly just pressed on. CarveOne
| Integrated stepper motor? with built-in stepper motor driver | uirobot | Product Announcements & Manufacturer News | 0 | 06-07-2010 03:59 AM |
| ATC Retention knob | JerryFlyGuy | Mechanical Calculations/Engineering Design | 39 | 04-07-2009 09:58 AM |
| Beltdrive-stepper motor-stepper motor driver | Georg | Stepper Motors and Drives | 0 | 10-16-2007 04:56 PM |
| 0,0 by Jog or Crank? | Pretorien | Benchtop Machines | 6 | 03-17-2007 07:36 PM |
| Retention Knob Help | 1gonzo | Machine Problems, Solutions , Wireless DNC, serial port | 1 | 03-17-2006 10:44 AM |
