Hey Guys, I bought one of the FLA-200 kits from Nate and recently started assembling it. I have a question regarding aligning the X and Y axes... namely - what's a good way to do it? as far as being mounted to the 8020 extrusion, the X axis plates are within .001" over the entire length but from one plate to the other they seem to be out by a mile so the bearing carriages are tight on one end and not even touching on the other . Also, once the X is fully aligned, how do I make sure Y is perfectly perpendicular to X... and how the heck do I know X and Y are perfectly straight to the machine?! Sometimes certain things escape me and this seems to be one of those time... 12 axis mill/turn center? no problem... assembling a simple 8020 machine and i'm all thumbs it seems... |
| well i've figured out that by some odd chance one of the legs on my machine is out of square so i'm going to have to go back and tweak some stuff around until i get it to line up properly. i think that is part of my problem. One thing i've found, though, is that once it's tightened, there isn't much play in the framework of the machine so i'd assume the X wouldn't be off by too much. The one thing I did do, though, is I measured one bearing block to the proper spacing off of the E drawing, squared it up, tightened it down real good and then held both bearings to the slide plate with a c clamp which, in theory, should make Y square to X... or at least I am hoping... I'm still having a binding issue because of that one out of square leg so I have some fiddling to do later when i get home.... |
| One thing Nate told me is that the mounting of the legs relative to the support frame is critical - he suggested trying to get it within 1/64 if possible. Although the drawing shows the legs attached to the top X beam as an assembly, he suggested building the support frame, getting it square, and then attaching the legs to it - getting them square to the support and equal lengths support to end. Then mount the top (X) beams on the legs, get them square, ... I think you need the frame to be very square before you try to get the rails parallel to each other. At least that's how I interpreted what he told me. My FLA300 (4 x 4) kit second shipment is being delivered today, so I get to try all of this out this week. Good luck - post pictures and let us know how you succeed. I do think that Nate ought to spend some time putting together assembly instructions. It may be obvious to him how it should be assembled, but it's not so obvious to me. |
| yea i think the one mistake i made was not squaring up the legs with the table frame before i put the X rails on. I'm square on 3 of the 4 corners but i'm out on one. i'm gonna have to loosen and adjust via large striking device... you can't really beat the guy up for being a little slow as far as instructions go... i, like him, operate a night/weekend business and when you work full time it gets overwhelming. i'm sure he didn't think for a second he'd sell as many kits per week as he has been... I make electric guitars and pickups as a side gig and I know when I get more than one or 2 pickup orders a week it gets tough... especially when i also get refinish, refret and repair work in as well... i have a whole wall dedicated to other peoples stuff I have to get to... I think Nate has been doing a fine job considering his workload... |
Hi Guys, I have this site bookmarked: http://www.overclock.net/case-mod-wo...ustom-cnc.html Hopefully it give you a little more info...... Howard |
I bought one of the Fla 200's also...took Nate a while but he was swamped.. I have since widened the table to be 65" wide(need one more piece of 3030 to finish it) and then lengthened it to 8 feet! Just drilled the rails 50 some holes on each 8 foot length of rails.. Also have a one of a kind Wolfgang engineering Z axis (7" travel).. this is keeping me busy just doing the table....during the winter i plan on doing the control box...using hall effect switches for the limits and rare earth magnets... then solid state relays for the spindle and vacuum system so I can stagger the turn on times and current loads... have fun with it i sure am!! |
#11
I think Nate is much busier than he anticipated when he started this business. He typically responds to email on the weekends. If he appears to be ignoring you, it's probably because he's hoping to get a couple more out the door before he says yes to another job. But I can't really speak for him, that's just speculation. |
#12
| These questions have been asked elsewhere, but no response. I'm guessing you guys probably have some runtime on your FLA200's by now. I'm on the fence between the FLA100 and FLA200. I've been thinking of scaling up the FLA100 to 2.5ft x 4ft. Will widening by 6" cause racking problems? Bed sag? Thanks, Scott |
| Build Thread- Fine Line Automation 8020 based Router Table | JohnB810 | DIY-CNC Router Table Machines | 18 | 04-24-2011 04:51 PM |
| Fine Line Automation Reviews and Questions | Matt Clara | DIY-CNC Router Table Machines | 77 | 10-15-2010 02:58 PM |
| New Machine Build- Fineline Automation 2x4 Rack and Pinion build | crash5050 | DIY-CNC Router Table Machines | 19 | 09-22-2010 05:00 PM |
| Fine Line Automation Closed? | spm | DIY-CNC Router Table Machines | 5 | 09-07-2010 12:50 PM |
| Fine Line Automation - Affordable CNC Parts for use with 8020 Extrusion | solodex2151 | Product Announcements & Manufacturer News | 28 | 02-27-2009 11:37 AM |
