| attach a schematic that followed from Camtronics I did use the same exact components |
| Chances are, the phasing is incorrect. Either reverse the encoder wires OR the power leads to the servo motor. Works 99 times out of 100 I read you have hooked the A phase on the Encoder to the A phase on the gecko? I have had that problem on a couple of setups for various reason. Doing as stated in the first line took care of it.
__________________ Art AKA Country Bubba (Older Than Dirt) |
| You can test to see if the encoder is working by wiring everything up but do not connect the motor power leads. With the Gecko drives powered on you should be able to turn the motor a small amount and the drive will go into fault. If it does not, the encoder is not functioning properly. The instructions tell you to do this test first. Did you? I would guess the +5V to the encoders is reversed. |
| I did turn the servo small amount but the drive wont' go to fault. Should I replace the encoder or what because I did reverse the wires without any good result
#10
| Another possibility is the encoders are drawing more than the 50 ma allowed by the gecko! No, do not try to reverse the polarity of the power to the encoder if it is correctly hooked up. This is a dc circuit and the electronics would not like it. (= magic smoke)
#11
| USDIGITAL, enconder E5-250-250-N-S-D-D-B |
#12
| There been problems in the recent past with those encoders. Read up on it on the the Gecko website and how to fix it: http://www.geckodrive.com/upload/UsingHEDSEncoders.pdf
| Problem- Servo runaway issue | EPTech | Fanuc | 2 | 09-02-2009 12:06 PM |
| Need Help!- Gecko Servo Drive Current Issue ?? | ballbearing | DIY-CNC Router Table Machines | 3 | 07-25-2009 05:51 PM |
| Servo Turret Issue | Tom Slick | Fadal | 13 | 03-03-2008 10:34 AM |
| Anilam Crusader II X-Axis servo card issue | ajithbora | Bridgeport and Hardinge Mills | 4 | 02-09-2008 05:56 PM |
| Mazak/Mitsu servo controller issue | carbidecraters | Servo Motors and Drives | 5 | 07-27-2005 04:20 PM |
