I built a fixed gantry hybrid (aluminium & MDF) machine. I haven't installed any limit switches yet and planning to use the soft setup for the time being. One thing I can't configure is Z axis: don't really understand whether I'll configure "0" at top or bottom. For instance, if I set zero at top then bottom (base plate) will be -6.10. | (0.00) | | (-6.10) --- Please advice, what you guys are configuring for you case? |
| Thank you, Phife. It helps me for Z setup. I also need some help on material setup (since I'm first time with CNC). For instance, my base plate is at -6.10 and I put the material (i.e height 0.75") there for curving. How do I configure it in Mach3? Thanks in advance. Last edited by leaveme; 09-05-2010 at 12:59 AM. |
| I do not understand the last paragraph i.e. 0.75" dia you need to explain this Phil |
| Interesting views. I run the opposite, the Z axis is at 0 when the tool is at the deck, which is set by my Z tool height setter. Then if I make a cut at Z=2mm it makes the material 2mm thick etc. I can't imagine any Z system better than that, but maybe there's something I missed. |
| I got a shovel, see I am standing on the ground at sea level... I dig a hole 1M deep, is that I added a meter hole? or I subtracted a meter hole? I dont know go figure? Safe "Z" covers the tallest trees in the forest? is that 100M 0r is that -100M? I guess I am saying I want my submarine to go - and I want my airplane to go + I'm just saying?
__________________ Hey check out my website...www.cravenoriginal.com Thanks Marc |
#10
| I would defiantly recommend probing for material height. I use Machblue screen set with a few mods to the probe scripts to suit my needs and wouldn't be without it, must save me 30mins a day compared to messing with slip gauges etc. The other probes such as edge finding and hole centering probes are very useful when needed as well. I always work in the negative and my Z Machine zero coordinate is at the top and homes to this. I think you'll find this is the more common way people work. |
#11
| If the finish height on a part is 2" I might measure to the table top and factor in the 2" in the touch-off dialog box. Depends if the unfinished top surface is irregular. (That's assuming the part is clamped directly to the table.) If you're running multiple tools there are more decisions to be made.
__________________ Anyone who says "It only goes together one way" has no imagination. |
| Need Help!- Mach3 A axis (4th axis) setup? | cadcamslawek | Mach Software (ArtSoft software) | 10 | 01-17-2012 08:23 PM |
| 4th axis setup? | compunerdy | Tormach PCNC | 5 | 01-06-2010 02:16 AM |
| Need Help!- Z axis setup | planetxfred | PlasmaCam | 1 | 12-29-2009 11:28 AM |
| x axis setup | bluc | DIY-CNC Router Table Machines | 21 | 09-27-2009 09:48 PM |
| Z Axis Setup | musicmkr | DIY-CNC Router Table Machines | 5 | 06-09-2004 11:33 PM |
