| Ball nose is your best bet, depending on the detail needed, I use a 1/8 and 1/4" ball nose for most of my 3d work. You can get pretty good finish if you use a small stepover but the trade off is increased machine time. |
| Depending on the size of the work piece, cutting the surface with a fly cutter mounted in the spindle as the work piece rotates, will give you much better results than a ball mill ever will....and you can cut both convex and concave shapes with the same tool and slightly modified programming....inverting x or y, depending on which axis the 4th is mounted on |
| Engrave on a curved surface | keebler303 | ArtCam Pro | 6 | 09-03-2009 07:03 PM |
| Help with projecting a setch on to a curved surface | Craigpat | Solidworks | 7 | 02-09-2009 07:59 PM |
| Need Help!- Curved Surface Toolpath | ehsanmax | Mastercam | 8 | 03-13-2008 06:39 PM |
| Engraving a curved surface? | wyobmf | Rhino 3D | 8 | 05-29-2007 09:13 AM |
| text/dingbat to curved surface? | Dougotio | Rhino 3D | 2 | 01-18-2006 06:58 PM |
