Old 08-31-2010, 12:53 PM
br1 br1 is online now
br1 is on a distinguished road
Which ball screws to use.
Old 08-31-2010, 02:48 PM
Dorsal is on a distinguished road
The pretty ones!
Now, would you like to tell the class what you plan to do with these ball screws? Specifically, how much weight / mass you will be moving, what dimensional resolution you plan to achieve, how will you be driving the screw, how fast (in I.P.M) you want to be able to drive your axes?
Old 08-31-2010, 02:51 PM
Ha ha thats a good one, I think I found the answer to what I was asking thats why I took the question off.
Old 08-31-2010, 03:12 PM
Old 08-31-2010, 05:01 PM
ger21's Avatar
If everyone deleted there posts, nobody would get any help here.
Old 09-01-2010, 12:15 PM
I wanted to find out what size ball screws were the same size (or close to the same size) of 3/4-6 acme screws being driven with 425oz stepper motors (xylotex 3 axis kit) I use this to cut 3/16 brass sheet at about 20ipm at a depth of .02 And how to input that information into Mach3. I was wondering if it was worth the effort then I realised I didn't have enough information to ask the question only after pushing the post quick reply button.
Old 09-01-2010, 04:17 PM
mactec54 is on a distinguished road
br1
The closest to 3/4x6 would be 20mm x 5mm pitch or a 20mm x 10mm ballscrew if you want a little more speed, You can find inch ballscrews as well that would be close as well
Mactec54
Old 09-01-2010, 04:25 PM
Thank-you that helps
ball screws chevdrgtrk Bridgeport and Hardinge Mills 1 03-30-2008 11:37 AM
ball screws morbius Bridgeport and Hardinge Mills 2 06-05-2007 03:37 PM
Ball screws, Acme screws, threaded rod DJ Morrow DIY-CNC Router Table Machines 11 03-22-2007 12:39 PM
Ball screws BluesMagoos General Metal Working Machines 1 01-08-2005 12:09 PM
ball screws anyone! turmite DIY-CNC Router Table Machines 0 01-13-2004 07:25 PM
