Hi, Iam building a 4th axis for my CNC router Iam thinking in use two different pulleys an a tooth belt Is a lot of info in web, but Iam not sure if is right for me. My Steppers are Nema 23 1/4" shatf 305Oz/In Iam Looking in SDI-SP.com but 1/4' shaft in my steppers limit the search. Finally I select the bigger pulleys pitch and belt with as possible. My selection is Pitch 0.2inches (5mm) Belt with 0.375 inches (8.9mm) Reduction 1:4 using Pulley 1 15 Teeth 1/4" bore Pulley 2 60 Teeth 1/2" bore Is 0.2" pitch addecuate for this kind of work? I tried to select 0.375pitch but any small pulley had 0.25 inch bore for my steppers Do you think that this selection is enough for turning/milling soft wood of 150-200mm diameter and 1000 mm max lenght? Can you sugest me other economical pulleys and belt suppliers? Whats the best practical belt material? Thanks in advance Rene Home |
| I think you need to use two belts to get a higher reduction, closer to 8:1 or more. At 4:1 you probably won't have enough holding power.
| Hi , Thanks for your response. But Is a god selecction use a 0.2" pitch pulleys or I shuld use a bigger pitch.? I saw some 4th axis in web using small steppers, but I don't have idea about how can do job using small steppers. Thanks Rene |
| Need Help!- 4th axis build | contactirfu | DIY-CNC Router Table Machines | 4 | 11-03-2009 09:50 PM |
| Need Help!- First build need help with z axis | IdeaMan | DIY-CNC Router Table Machines | 7 | 04-16-2009 09:53 PM |
| 5-axis self build? | Ernesto | Commercial CNC Wood Routers | 56 | 03-18-2009 08:29 PM |
| Need Help!- 2 AXIS Build | gunlocators | DIY-CNC Router Table Machines | 8 | 09-23-2008 05:56 PM |
| I want to build a 6 axis | DOMDEC | CNC Wood Router Project Log | 26 | 07-03-2006 07:26 AM |
