Old 08-29-2010, 04:29 AM
zeed is on a distinguished road
will this work(small Zaxis)
I got one small linear acutator and was wondering could this be used as Z axis on a small cnc?
I has 70mm travel and 6mm rods with 4 linear bearings.
It had a small pneumatic piston in the middle witch I removed and replaced with threaded rod.
I also plan to support the 6mm rods on boath ends...
Old 08-29-2010, 08:29 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Probably not.
It has no means of supporting itself. Most Z axes are supported on both ends with a sliding part that runs between the two end supports.
Some are a little different by being fully supported, but the result is a carriage that moves between point A to point B.
With this one, you only have one moving element and when extended, is not supported.
Lee
Old 08-29-2010, 11:35 AM
CarveOne is on a distinguished road
I agree with LeeWay. Also, 6mm rods are very small for a Z axis that will have any amount of side load on it while cutting.
You may be able to use it for making a CNC pen plotter.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 08-30-2010, 03:14 AM
OK.thanks for your replies,I am in the middle of my new machine build and was hoping that this will be my Z axis.
Well,back to the drawing board.
Old 08-30-2010, 10:10 AM
baithog is on a distinguished road
Well, why not - Screw the rod supports at each end to a plate that you attach to the Y-axis trucks? Make the threaded rod in the center long enough to attach a motor coupler or a pulley.
The real questions would seem to be:
  • Are the bearings on the support rods tight enough for the spindle and application?
  • Is it strong enough, rigid enough to support your spindle?
  • Can you reduce the backlash in the screw to acceptable levels?
  • can you fabricate a spindle mount that will fit on the carriage?
  • Can you live with the minimal travel?
Larry
Need A Quote- Small Part Repeat work millman52 Employment Opportunity 19 11-05-2009 05:57 PM
Use of CNC Router in small Cabinet work mccafferty WoodWorking 10 02-17-2009 09:16 AM
Small engraving work on X4 john_t_h Syil Products 6 07-19-2008 09:49 PM
will Camsoft work on small mills skipper CamSoft Products 2 12-06-2007 10:28 PM
will FANUC work on a small mill skipper Fanuc 0 12-06-2007 02:55 PM
