Old 08-27-2010, 11:35 PM
crane550 is on a distinguished road
Uneven table compensation
Hi all,
I know the proper way to handle this is to fix the table, but for now, does mach3 offer any kind of uneven table compensation? For example, I have one corner that is about 1/32 of an inch off. When I V-Carve down to that corner the change in my carving changes dramatically, that the width of my path is exactly off by twice the Z error. (Assuming 90* bit)
Any way I can tell my software "that corner is high/low?"
Old 08-28-2010, 03:38 AM
Superman's Avatar
Superman is on a distinguished road
I'll suggest to try looking at it from another direction
-Can you place your material in a way that would seem flat from the cutter's point of view instead of fixing the machine or NC code
ie place packers underneath to jack-up the stock while running a dial indicator across the top ( dial indicator is held by the spindle collet, DO NOT turn the spindle ON, or you'll find it on the other side of the wall )
Old 08-28-2010, 07:21 AM
CarveOne is on a distinguished road
Originally Posted by crane550 View Post
Hi all,
That might seem like a useful feature, but I'm pretty sure that Mach3 has no utility like that at present. It might require that you use a touch probe to create a reference height map database file of your table top every 1/2" or so, then create another height map database file of each piece of material that you intend to cut after it is fastened down to the tabletop, then use the software feature to generate gcode that compensates for the height map database file differences at each coordinate in the area that you are going to cut.
Bottom line is - surface plane your table and "make it right". It's a whole lot easier and faster and less problematic.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 08-28-2010, 08:46 AM
ger21's Avatar
You may be able to do it with the formula functions, but as CarveOne said, the easiest way is to surface the table flat.
Surfacing the table should be one of the first things you do with a new machine, and may need to be done periodically to maintain a flat table
Old 08-28-2010, 10:37 AM
eloid is on a distinguished road
spoil brd
yes resurface table top complete flat relative to you gantry, end result ...you will have a " your" table compensation if you like apply/ screw a temp. spoil brd on top of it, remachine as need... etc
Old 08-30-2010, 11:03 AM
analogman is on a distinguished road
Subtle twist on the other suggestions: bolt down a spoil board and then surface the spoil board. Use lot of bolts. I use a 1 1/2" bottom surface bit from grizzly.
This method works extremly well. After a spoil board surface I can engrave anodized aluminum which would really mess up if the surface was off by .002
Old 09-01-2010, 06:50 PM
Already done!
Old 09-01-2010, 06:53 PM
Already done!
sound like you lossing steps in your steppers and your spoil brd is wave as a result of that issue.
Old 09-01-2010, 07:00 PM
Not sure I follow...
Old 09-01-2010, 08:10 PM
stepper motor are open loop, if there not sized/ tunned/overloaded/
feed rate set to high, the motor will drift..... resulting in missing steps
  #11   Ban this user!
Old 09-01-2010, 11:31 PM
otto_pjm is on a distinguished road
If you want to go the code compensation route, have a look at this thread. I believe the end up with code for both EMC and Mach. The process is to take you g-code, height probe around it in a grid and average the heights, then update the code to cut as if the board was even. It's being used with extremely small bits for PC board cutting. It may take awhile to probe if you have a large area, but should be able to compensate, if you can't level / tram the surface to your spindle.
Pete
http://www.cnczone.com/forums/showth...t=82628&page=8
XY Angle compensation ? rdpdo CamSoft Products 1 06-25-2010 05:12 PM
Engraving and uneven surfaces phatjap DIY-CNC Router Table Machines 8 04-21-2010 07:11 AM
Uneven finish orbyog Mach Software (ArtSoft software) 13 02-05-2010 01:42 PM
Tool compensation ssozonoff General CNC (Mill and Lathe) Control Software (NC) 8 01-21-2009 09:06 AM
Need Help!- RAM compensation 15M PTtec Fanuc 11 09-25-2008 04:32 AM
