Old 08-24-2010, 12:45 PM
blueoscar is on a distinguished road
v bearing opportunity
hi all,
I have the opportunity to purchase these bearings (see photo) for 3 bucks a piece in quantities of 100. they are of nice quality with good bearings available in single or double bearings. they are .75" or 2mm in diam. Would this diam be useful for a 18* 16 router fore mostly wood?
Rich
Old 08-24-2010, 05:22 PM
gmfoster is on a distinguished road
Originally Posted by blueoscar View Post
hi all,
Rich
Something doesn't right here are you sure 2 mm equals anything close to 3/4 inch? Or is my head all messed up...
Old 08-24-2010, 05:34 PM
JohnnyChan is on a distinguished road
0.75in is equal to 19.05mm (which is close to 20mm). That's from memory from designing my virtual cnc in SolidWorks set to metric, and trying to use standard metal forms and parts. Fun stuff.
25.4mm = 1in
3.175mm = 1/8in
4.7625mm = 3/16in
6.35mm = 1/4in
9.525mm = 3/8in
12.7mm = 1/2in
19.05mm = 3/4in
Old 08-24-2010, 05:37 PM
nuplowboy is on a distinguished road
0.75" is pretty much 19mm (19.05mm), close to 20mm
Looks like a missing zero...
Old 08-24-2010, 06:19 PM
sorry
about the zero it's 20mm
Old 08-24-2010, 09:10 PM
how about some feedback guys
johnmac's Avatar
johnmac is on a distinguished road
Are the bearings sealed? If not, dust in them will be a problem.
John
Old 08-24-2010, 09:21 PM
yes sealed,how about the size too small?
Old 08-24-2010, 09:43 PM
ger21's Avatar
Those are the #1 size. Most people use the #2 size, which can carry almost 3 times more load.
I think Widgitmaster used those on this machine, but they turned out to be too small.
http://www.cnczone.com/forums/showthread.php?t=52420
job opportunity mishikwest Employment Opportunity 1 01-08-2008 11:22 AM
Western MI UG NX4 opportunity rschap1 General CAM Discussion 0 02-26-2007 08:30 AM
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
Employment Opportunity Haas_Apps Employment Opportunity 1 12-26-2006 09:17 AM
Employment Opportunity maggirl Employment Opportunity 2 10-01-2006 11:42 AM
