I have been twisting my brains on this problem for a while now. I am not getting any luck with my motors. here is the setup: from the parrallel port, onto some 541 TTL signal drivers. from which i pickup the step and direction signals, then onto the geckos G202, then the motors. I have set the current sensing resistor to a safe 20K ( about 2Amps) and wired the hybrid motors in series (i have also tried parrallel). The geckos are powered from a 70V linear supply, and the 541 drivers from a 5V supply. I wired correctly the step, dir and comon connections. Here is the procedure: 5V is switched on, then 70V. Light on the G202 comes up. I use EMC2 to control the system. When i try to move any axis, nothing happens. here is what i checked: I checked all the wiring, and then i checked the wiring again. I used a scope to check the step pulses were getting through at the G202 input. They do, so does the dir signal. At first, i though the pulses looked a little thin (too fast ?) so i slowed them right down, and got some really long, slow ones to the geckos. still no luck. I checked the phase outputs, using the scope. I do get some 70V, nicely chopped signal through to the motors. sometimes on one phase only, sometimes on both. (i depends which G202 I am plugging into. I have 4 of them). So i guess the G202s are doing there job to keep the motors holding still. however, no change on the phase outputs when i press the jog key. I swapped geckos, i swapped phase order..i must have tried everything i could think of. The worse thing is that i did get the motors running during initial testing, about a month ago, just to test the G202s. the motors turned very well, without a single setup problem. I am now using the same supply, same motor, and same controlling software, but i cant solve the problem... any idea what i should check next ? |
| Ok, i had one more night sleep over it. It must have been a good night. I worked out where i was going wrong. The common connection is not common "ground" (otherwise, the G202 does not have any means of knowing the amplitude of a step pulse.. it could trigger at 2V or 3.3 or 5V). common has to be the +5 ref from the 541. i checked the manual, and of course, it is. tried this this morning, and i have motion ! |
| Trade offs between Moving Gantry and Moving Table | gregmary | DIY-CNC Router Table Machines | 11 | 04-22-2011 01:48 PM |
| Motors not moving | neric | DIY-CNC Router Table Machines | 3 | 07-27-2010 04:58 AM |
| Need Help!- Mach3 not moving motors | jasper371 | Mach Mill | 2 | 06-15-2009 04:32 PM |
| Motors not moving | lamicron | Mach Mill | 14 | 05-19-2008 07:54 PM |
| Moving Table vs Moving Gantry; Dremel vs Router | chuckknigh | DIY-CNC Router Table Machines | 32 | 03-27-2007 08:48 PM |
