Old 08-17-2010, 04:15 PM
energyforce is on a distinguished road
Servo not tight as I'd like it - how to improve?
Hey,
My total reduction is approximately 9:1 on the y axis. The reduction consists of pulleys-belt and sprockets-chain.
Youtube movie here shows how much the y axis moves when I put about 20 lbs of force on it. Crappy-ass dial indicator indicates about .08 of movement.
Movement is, for the most part, coming from the motor not being able to hold it tight (motor shaft is moving).
Is this bad or good compared to all them other homebrew router tables out there? How can I improve?
I know a ball or leadscrew system will eliminate this as it is not "load-reactive." But what else can I do?
Thanks...
Old 08-17-2010, 07:55 PM
packrat is on a distinguished road
This looks more like a back lash/ clearance problem in your drive. Roller chains are full of clearance and so are gear reducers. Are you using a rack and pinion? More back lash if not set-up right.
Even a acme screw drive (not a ball screw) would be better.
Old 08-19-2010, 10:17 PM
Actually the motor is doing the moving, not so much the backlash/clearance. The motor is reacting to the load we are putting on it through the belt/pulley and chain/sprocket...
Old 08-20-2010, 06:08 AM
ger21's Avatar
Can you explain exactly what the reduction is and how it's connected? And what size servos, and what drives?
Help to improve Calibration ?s. Stampede Calibration & Measurement 3 01-05-2009 11:13 PM
Newbie- how to improve surface quality? davidsutton General CAM Discussion 4 07-15-2008 07:27 AM
Suggestions to improve Surfcam moldcore Surfcam 11 02-28-2007 12:46 AM
How can I improve the backlash on my X1? digits Benchtop Machines 33 01-27-2007 05:12 PM
How to improve/upgrade Prototrak Plus? cadsculptor Bridgeport and Hardinge Mills 1 12-21-2006 04:21 AM
