Old 08-12-2010, 11:11 PM
HereinCS is on a distinguished road
Geared stepper motor as a 4th axis?
I'm building a tiny cnc router and would like to consider a 4th axis. Can I use a geared stepper motor as a 4th axis? I'd make some sort of clamp to hold the material only the shaft.
Old 08-13-2010, 11:56 AM
jsheerin's Avatar
jsheerin is on a distinguished road
Probably not a good idea... You would probably kill the bearings in the gear box eventually. Better would be to setup a shaft with some radial and thrust bearings, mount some kind of chuck to it, and then drive the other end of the shaft with the motor. If you do a search in this forum you should be able to find plenty of examples.
Old 08-15-2010, 05:06 AM
simpson36 is on a distinguished road
Check this out for a belt reduction 4th axis:
YouTube- New Super Duty 4th Axis Rotary Engraving on mini-machining center
How much does a stepper motor have to be geared down for X and Y axis ? Danno Plasma, EDM and other similar machine Project Log 11 09-27-2009 11:23 AM
SAYAMA Geared Motor Help JackBlack General Electronics Discussion 1 02-19-2009 11:19 PM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 01:54 PM
Direct or geared reduction to threaded drive ? (stepper) andy_ck87028 Linear and Rotary Motion 4 03-13-2006 07:42 PM
Geared Stepper and Current Controll krazycnc Xylotex 3 05-31-2005 10:34 PM
