| I'm replacing the old all tread 1/2 12TPI . with a lead screw ACME most likely will order today or before the weekend. I will also be changing to VXB bearings. The bearings are on order 20MM linear bearing on open sliding units / with support rails for all 3 axis a little advice please, I would love to have your input use the bronze screw and flangs? use the Anti-backlash Leadnuts from DumpsterCNC? use the Flange Nuts from DumpsterCNC? the 3 new screws (x,y,z) will be .250 Turns per inch or .500 turns not sure yet which to order Mill cuts mostly plastics, uhmw, delrin 425 or 495 oz stepper not sure which. Thank you in advance |
| Is this a metal cutting mill, or a router? Do you have a pic of the machine?
| Tags |
| dumpstercnc, lead screw, mill |
| dumpster nut placement question??? | TchTchr | Joes CNC Model 2006 | 1 | 05-20-2009 09:21 PM |
| Anyone on board right now that can answer a programming question??? | MetalMolder | Fadal | 1 | 06-28-2008 10:47 PM |
| New guy question..Need a where to learn answer | drink2mny | CNC Plasma and Waterjet Machines | 11 | 03-01-2007 12:13 AM |
| easy to answer question | senor J. | Mach Software (ArtSoft software) | 2 | 01-27-2005 06:34 PM |
