| Hello to all, I build cnc long time ago, after MDF build, there is aluminium machine now. Machine uses steppers end electronic bought from eBay ![]() I don't know specs of motors but i think they are : Torque 1.7n.m 245 oz.In. Length, width and height=3.1"---2.3" ----2.3" =78mm-57mm-57mm MDF machine worked ok Aluminum one great, I had 1400 mm/sec without problem. 2 weeks ago machine electronic (driver) smoked (white smoke), so i bought TB6560 4 axis from ebay... Motors are just stalling, i changed all settings on mach, on electronic 1/2 step 1/8 etc... nothing changed Motors stall , on low speed they sound like they don't have bearings( khrrrrrr) after days reading here I'm thinking to go with Gecko g540 kit from keling http://www.kelinginc.net/CNCNEMA23G540Package.html I'm not sure what to get... what motors? Is 380 good or i need to go with 906oz motors? steppers on machine are 2:1 with belt, pitch is 5mm... I appreciate any advice!
__________________ www.mycnc.giveinfo.net My CNC machins, pictures and videos. |
| Hi GI. You were running Nema 23s before--About 200 ounces, judging by the size. You DEFINITELY don't need the 906s. The G540 can't really USE anymore than 8A, so I would go with the 7.3A PSU. That should be sufficient for all four of your axes. The 381 motors run better with G540 than 387s. This is what I recommend: http://crevicereamer.com/Page__57.html Just add an extra 381 for your fourth axis. You should be able to run the 381s geared 1:1. That would give you 250-300 IPM rapids--Or up to 7600 mm/min. CR.
__________________ http://crevicereamer.com Too many PMs. Email me to my name plus At A O L dot com. |
| GI: You're asking me to take a lot of responsibility, but I accept. I am confident you will be pleased. I have never heard anyone complain about G540/381 performance. You should be more than ok with this combo. I WILL backtrack on my 250-300 IPM though, that would be if using 5 TPI ball screws. This commercial machine uses G540 and 387s, which are slightly slower than 381 motors: YouTube- IronMan CNC Router 4 AxisHere's someone who has discovered how powerful G540/381 are--Even on a large router: http://cnczone.com/forums/showthread.php?t=107030 I wish you a safe return trip. CR.
__________________ http://crevicereamer.com Too many PMs. Email me to my name plus At A O L dot com. Last edited by Crevice Reamer; 08-05-2010 at 01:47 PM. |
| thank you, I'm just sending kit, and then remotely setup Mach 3. I moved to USA, all work i do is remotely online ![]() They just need to load code, zero axis and start machine
| Ah! I see. Don't forget you will need four 3.48K resistors. Better send some extra fuses also. http://crevicereamer.com/Page__57.html Make sure computer parallel port is set to EPP in bios. Be sure to download Gecko .xml file into Mach3 directory. http://crevicereamer.com/Page_101.html CR.
| Fuses for Gecko ? I know about EPP, i need to check that... As i see, for all people that are starting with cnc the best thing is to go with G540 and keling motors from start... because they will save little more money with chinese cr*p driver and motors from ebay and later they need to spend double money to fix problems and headache they have
The G540 is unkillable, but you CAN kill the internal fuse. It's a special fuse, not generally available. It's the first one on the list. Better send some spares: http://search.digikey.com/scripts/Dk...8-nd&x=21&y=24
CR.
| I made order. From kelinginc G540 Kit with 381oz motors, 12.5 amp PS, and Stop switch. from cncrouterparts.com 76 foot of cable ![]() Hopefully i will change this motors with new 381
| Tags |
| cnc, g540, stepper |
| Can anyone recommend a keling driver for my machine? | tacogrande | Automation Technology Products | 5 | 05-05-2010 12:57 PM |
| G540 with Keling 8-wire | heathric | Gecko Drives | 6 | 04-08-2010 08:29 PM |
| Keling 6056 driver & 425 steppers | flyinwilly | Stepper Motors and Drives | 0 | 02-18-2010 05:48 PM |
| Need Help!- Would you mind to help me to solve the problem for Keling stepper Motor Driver? | qangel1000 | Stepper Motors and Drives | 4 | 08-07-2009 12:23 AM |
| I can't get my keling 387oz-in motors to step evenly with my G540 | codevark | Gecko Drives | 0 | 03-16-2009 11:32 PM |
