Was looking at the Ekstrom, with a max rpm of 18k. Does anyone know in general the cutting rpm in different types of materials. I know this depends on bit size, but just in general. Thanks. |
| http://www.pdscolombo.com/pdf/PDS%20...0Care%2007.pdf Read page 3 for calculations for feedrates for various materials. |
18K is good down to around 1/8" bits. If you want to use smaller bits at speeds over 200ipm, you might want 24K.
| and also what is feed / tooth means?? I'm so confused by this engineering calculation please help THank you much in advance |
| There are many tutorials out there. http://machine-tools.netfirms.com/17...ed_Milling.htm http://www.endmill.com/pages/training/spdfeed.html Al.
#10
Can someone got a simpler way to teach my numbing brain? |
| How fast to run a motor with a VFD? | TheGreenMachine | General Metal Working Machines | 3 | 05-12-2010 08:28 AM |
| Need Help!- How fast a spindle speed can you really use? | leeputman | Metal Working Tooling | 12 | 03-03-2009 03:25 PM |
| Spindle speed showing 2x to fast | fatal-exception | Mach Mill | 4 | 10-18-2007 11:12 PM |
| Bridgeport spindle brake - how fast should it stop? | swarf_rat | Bridgeport and Hardinge Mills | 5 | 07-01-2007 01:11 AM |
| Spindle speeds - why so fast? | Cowbell | General Metalwork Discussion | 6 | 01-19-2006 07:07 AM |
