Old 08-02-2010, 02:32 PM
bandtank is on a distinguished road
how and where do i mount my limit switches?
I can't figure out how to mount my limit switches. I am going to put two on each axis, one set will be used as limit and home switches while the other will purely be limit switches.
I asked "where" because I want to know if people typically put them on the moving part of each axis or if they are typically installed in a fixed location at the boundary of axis travel.
I can't figure out a good way to attach them to my machine. Should I tap some holes or use a strong double sided tape? I just don't know what people typically do.
Name:	2010-08-01 20.59.33.jpg‎
ID:	112041   Click image for larger version
Name:	2010-08-01 20.59.47.jpg‎
ID:	112042   Click image for larger version
Name:	2010-08-01 21.00.02.jpg‎
ID:	112043   Click image for larger version
Name:	2010-08-01 21.00.15.jpg‎
Name:	2010-08-01 21.00.45.jpg‎
Old 08-02-2010, 04:14 PM
CNCAAB is on a distinguished road
hi.
i normally see it on a fixed part of themachine, the wire will not move & that is good for the right work & maintenance. if yo can tap on the machine, it is good tipically this method is used by the manufacturers (sorry by my english)
Limit switches and homing switches AeroKam Open Source CNC Machine Designs 16 01-05-2008 07:56 AM
CNC limit switches ptjw7 CNCzone Club House 5 01-21-2006 06:02 AM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
