#1321
| You're right, I bought it from DamenCNC, in December 2010. Shipping was EUR45 for a quoted 6-8 day delivery, but with Christmas it sat somewhere between Customs and Australia Post for a few weeks Not DamenCNC's fault, but something to keep in mind if you order at a busy time.That Bosch trimmer looks pretty good! It looks to have a better power switch than the Kress. I really don't like the slide-and-press switch, a simple rocker would be much better for my needs.
__________________ WARNING: I am not responsible for links in my posts unless I specifically refer to that link. CNCZone is modifying posts. Click these links at your own risk. |
#1322
| To be honest, I didn't set out to buy the Bosch; it was the best option of the very limited range that Sydney tools had in stock. Compared to the lower end Makitas, the Bosch has an all metal bearing housing that would be stiffer for clamping to a Z axis. It also had a chromed collet compared to a black passivated collet in all the other models I saw - might be less likely to corrode. The collet also had a shaft lock to make bit changes easier. The Makitas had much larger fans but the bearing support is mostly plastic, which might be more flexible. There are two Makita models with all metal bodies however they are not stock items and the Syd. Tools staff didn't even know they existed. If you ever wanted to use the trimmer off the MV3, the Bosch has a much stronger metal base with micro height adjustment. I don't have anything to directly compare the noise to, but the Bosch is much quieter compared to my three larger routers; I might not want to run it late at night but its definitely not annoying to work with up close. The collets in all the laminate trimmers are nowhere near as good as the Kress; they all have a very small cone with a single slot - that would be a problem if your bits were even slightly off 1/4". None of the trimmers had the built-in speed control that the Kress has; that's worth quite a bit if you don't already have an external speed control. |
#1323
| Hey John, just wanted to say thank you for the information you have shared here on this thread. I was able to upgrade the Y axis on my machine (not Microcarve) from 5/8" rails to 3/4" rails using your technique for mounting oilite bearings and pvc. Anyway, the upgrade really helped with rigidity and reducing 'bounce' from the Y rails flexing with rapid Z movement and I just wanted to thank you for the information, it sure helped me. Don |
#1324
Thanks Very Much, Don! ![]() It's always Very Nice to hear that something in these posts is useful to others. ![]() John |
#1325
| John there is a vast amount of useful and diverse information hidden away in this thread. Maybe you could make an index page with links to specific topics that have been discussed along the way ? it would make a very useful resource ! just an idea ![]() Rich
__________________ My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html |
#1326
| I've been ...(sorta)...working on that along... ![]() It'd be a lot simpler if I was able to edit a post and add info as I locate it, but I have to try to gather it up so I can do it at one time. I have to dig through myself to refer to pictures and info, so that's taking lots of time. ![]() John |
#1327
Maybe a 'group' project ? so many pages each. I'd be happy to chip in ![]() Rich
#1328
| I do have a certain trick I use to find stuff. It works pretty well too. That's to type in Google, "microcarve" "cnczone" and some other word that should be normally expected in a post that contains info I'm looking for. Example, "microcarve" "cnczone" and "painting"......(without the quotes) Then I look on the Google image search results. I usually can locate whatever post I'm looking for.... ![]() There have been so many topics that I forget what's here lots of times. I wish I had a special award for those who've read the whole thread. They surely deserve one. And if I ever win the lottery, I'll make sure they get that reward. ![]() John |
#1329
| "I wish I had a special award for those who've read the whole thread. They surely deserve one. And if I ever win the lottery, I'll make sure they get that reward." John, I HAVE won the prize as I have learned a lot from reading this thread from the beginning:}) I also (because of this thread) got some great steppers for my machine!
__________________ Art AKA Country Bubba (Older Than Dirt) |
#1330
| Finally finished!! Thanks John for sharing your knowledge. Back in post #435 you were discussing using Alumilite for anti-backlash nuts. I made a silicon mold of the threads and then cast the nut around this mold instead of around the metal threads. It has worked well for a couple of years now. Heat has never been a problem. Maybe the leadscrew is acting like a heat-sink. A question, when you cast the large blocks of Alumilite, do you use a wood mold or a large silicon mold? Thanks Dave |
#1331
#1332
Thanks! ![]() I have several "trial runs" at making nuts from the urethane. They all do work well, but I don't trust them quite enough to send them out with machine kits....Delrin is cheap and reliable. But then sometimes a tap needs to be made...so again, it's a trade off. It can say that when the urethane slides against a *well polished* surface, it holds up extraordinarily well. I use slide plates on my lathe made from it. But...any place that's not very smooth can abrade it fairly easily. That's the same with iron or brass, though. The roller bearings I made from it work Great and are actually good for fairly low RPM applications. The ball bearings burnish the material and seat themselves very well. Molds.... Wood molds are easier than messing around with $$$ silicone rubber, but as you know, sometimes the rubber is the better choice. Tupperware type containers also work well. Too bad they don't make them simply rectangular like they used to. Now they all have space-age curves and odd shapes that need to be wastefully cut away when casting something as simple as a plain old block for further machining.... ![]() Just wax the heck out of the wood mold so the urethane doesn't stick. ![]() John |
LinkBacks (?)
LinkBack to this Thread: http://www.cnczone.com/forums/diy-cnc_router_table_machines/109390-my_newest_desktop_machine.html | ||||
| Posted By | For | Type | Date | |
| www.elektronik.si :: Poglej temo - Skupinski projekt - CNC | This thread | Refback | 10-04-2010 09:14 AM | |
| Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
| desktop cnc machine | dhelfter | EBAY ADS | 1 | 08-18-2009 10:11 AM |
