Old 07-30-2010, 02:20 PM
TurboGt is on a distinguished road
Whats this stuff worth?
Hey guys I need some advice.
I was given a 2-axis water jet machine (missing all of the water jet components) and was planning on making a 3-axis router but have been so busy that I have not had time to do anything with it.
What do you think the Linear bearing, y-axis, ball screw, stepper motor, wire looms (the black flexible ones pictured with the stepper motor) would be worth? I have someone interested and am not sure what to let it go for????
Any advice would be very helpful... The person is coming tonight to look at the stuff.
Thanks for your help guys,
-Marq
Here are some pics of the stuff......
(I did not get the blue steel frame just the bearings and motors)
The setup has 2 stepper motors (one is attached to the y-axis):
-Vexta 2-phase, 1.8*/step, 4 amp, 0.75 ohm, model number PH299-E4.0
-ISEL-Automation 2-phase, 1.8*/step, 2.8v, 2.8 amp (uni), 4 amp (bi), model number 473030
It is listed as having 110 Ncm torque output.
http://www.cvtech.com.au/automation/smotor.htm
-Enclosed y-axis (4 ft 10 in long) with attached stepper motor
and a 5.5 foot long ball screw
-Two 6.5 foot linear bearings with 4 pillow blocks
A long time ago I found bearing manufacture ..... they are made my Isel. They are their series 1 bearings and can be found here:
http://www.techno-isel.com/lmc/Products/iselrail1.htm
Old 07-30-2010, 02:41 PM
awerby is on a distinguished road
It's hard to say
If everything's in good working condition it might be worth $500 or so to someone looking to build a router. But if the ball-nuts are messed up, or the rails are dinged, the motors are bad, etc. it would be worth less. What's that table made of - solid aluminum 2" thick? If so, the value goes up a bit.
Andrew Werby
www.computersculpture.com
Old 07-30-2010, 02:50 PM
Everything was working when I took the machine apart..... I was not given the water jet components because they were used on the upgraded machine they built to replace this one.
As for the aluminum table (actually a water tank/reservoir) it was super thin aluminum that was not worth taking so I think it was recycled..... But I did take all of the aluminum square channel you can see holding the water tank in the pic.
Old 07-30-2010, 03:00 PM
MrWild is on a distinguished road
The steppers are old style, weak ones compared to new ones. The stand will need bracing as a router puts out more forces. You would get more money parting it out. I would pay $300 and walk from $500. That's just me, but used is used, and old tech might work for low cutting forces of a water jet, but not for a router. By the time you upgrade everything else, there isn't that much savings.
Old 07-30-2010, 03:28 PM
HereinCS is on a distinguished road
I paid $300 for a similarly sized y axis. But mine is almost new looking and has ground ballscrew. I'd pay $200 for something like yours. But other than the y axis, and possibly the matching rails, I'm not sure I'd want the rest of the stuff.
Need Help!- Whats our table worth? craneman CNC Plasma and Waterjet Machines 3 12-22-2009 09:15 PM
HLV-H Lathe - Whats it worth? kevini Hardinge Lathes 4 07-02-2009 03:05 PM
'03 TM-1, Whats it worth? smittys800 Haas Mills 10 03-10-2008 05:32 PM
whats the deal with all this epoxy base stuff axkiker DIY-CNC Router Table Machines 3 02-08-2008 06:09 PM
What's this stuff worth? Dave1 General CNC (Mill and Lathe) Control Software (NC) 1 03-19-2007 10:00 PM
