Old 07-30-2010, 11:54 AM
WannaBe3D is on a distinguished road
Decisions, Decisions...
Ok, to say that I'm a newb is an understatement...I think. I've been doing research for about the last 3-4 weeks and have more questions than I started out with...
I want to build a CNC machine, but I'm not sure if 3-axis can accomplish what I need to do.
Reason: I need to build my CNC to be able to make R/C helicopter parts. Most of these parts will be made of aluminum, some of plastic (Delrin). Most parts will be symetrical, but I want the ability to do asymetrical parts as well.
These parts will be fairly small (800mm X 800mm X 400mm max), but fairly complex.
What I want to build is simular to this picture, but with 7 "spindles." I know the design above isn't all one piece, but I need to be able to produce all of the parts needed to complete a design like this.
Also, you can't see it in the picture, but on the bottom of this piece there is a "mount" that sits on the end of a 12mm shaft.
Budget: I have set a budget of $1,500 USD.
Complications: I'm having a hard time determining a layout to accomplish what I need. I'm also not sure how many axis I need to accomplish my goals.
Any advice?
Old 07-30-2010, 03:20 PM
rbcmetalwork is on a distinguished road
"These parts will be fairly small (800mm X 800mm X 400mm max), but fairly complex."
Was this a typographical error? Perhaps 80mm x 80mm x 40mm?
Randy
SV-2412, 0i Mate-MB
Old 07-30-2010, 03:22 PM
Nope, I meant 800 x 800 x 400...(relatively small)
Old 07-30-2010, 03:33 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
that's a 4 axis job if you plan to machine it complete , or easily a 3 axis with some fixturing that you can manually rotate the part at an M0
if you fixtured right and do some funky toolpathing then you can complete it in two ops with either 3 or 4 axis . it all depends upon how creative you are
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 07-30-2010, 03:38 PM
What does theat mean?
On a 3-axis, I can cut the top side, turn it upside down, and cut the bottom side right?
Old 07-30-2010, 04:03 PM
Drools's Avatar
Drools is on a distinguished road
800mm = ~31"
That is small?
Old 07-30-2010, 04:04 PM
Ok, forget that I even said "fairly small"
Old 07-30-2010, 04:31 PM
Drools's Avatar
just a question off topic, what scale of copters are you working on?
Just for comparision my 3 axis 8020 based gantry style machine based upon mostly cncrouterparts.com parts cost me about 2000.00. The size is X30, Y20, Z5.
Is it possible to build a 3 axis @ 35,35,5 for 1500.00?, maybe if you can get some deals.
Old 07-30-2010, 05:29 PM
dertsap's Avatar
Gold Member
there's more to machining that particular part than just that
yes you can machine both sides of the part to get the main body but you still need to machine the pins or the holes for the pins , and you'll need to rotate the part to 5 different points
Old 07-30-2010, 08:40 PM
tskguy is on a distinguished road
Talking
Dude I have flown RC helis for close to ten years. What kind of RC heli is going to need a 31" rotor hub??? It seems a little big to me. Shoot my 90 sized heli only swings 710mm long blades.
And have fun balancing a 7 blade head!!
  #11   Ban this user!
Old 07-31-2010, 12:45 AM
Obviously I'm not going to machine a 31" hub. The hub itself is only about 60mm in diameter.
I want to machine larger parts than the hubs, but the hub it the most complicated piece so I'm trying to see if I can get a mill to make it. That is unless you know someone who makes a 7 spindle hub with grip extensions...
  #12   Ban this user!
Old 07-31-2010, 01:20 AM
15mgtar is on a distinguished road
you can not build a precision cnc machine that will be able to do those jobs at $1,500 USD.
decisions stinker Benchtop Machines 6 09-14-2009 10:13 AM
Super Mini Mill - decisions TravisR100 Haas Mills 39 09-01-2009 10:21 AM
Decisions, decisions ranchak General Metal Working Machines 4 05-25-2009 08:10 PM
Controller decisions sYmbot2 CNCzone Club House 0 12-23-2008 03:18 PM
driver decisions pinussen Stepper Motors and Drives 0 03-20-2006 07:15 PM
