Old 07-29-2010, 11:34 PM
Momentz is on a distinguished road
Computerized mat cutter design and parts help?
I am a picture framer and so i have been looking at a computerized mat cutter but there so expensive, i was wondering if anyone has built one before? or know where i could get parts to build one like the rotating head witha blade to cut the 45deg bevelled edges
Thanks for your help in advance
Need Help!- Need Computerized Rotary Engraver Manuel Figueroa Want To Buy...Need help! 0 03-31-2009 03:23 PM
design of waterjet cutter esnusnu Mechanical Calculations/Engineering Design 6 01-07-2009 02:07 PM
New Machine Build- CNC LASER CUTTER/PLASMA/ROUTER DESIGN protomate Laser Engraving & Cutting Machines 6 08-25-2008 01:56 PM
Need some suggestions for wire cutter parts mrman CNC Wire Foam Cutter Machines 0 08-09-2008 01:45 PM
Computerized Coil Winder Build in Progress vacpress Musical Instrument Design & Construction 6 05-10-2008 07:20 AM
