Old 07-28-2010, 01:19 AM
guerd87's Avatar
guerd87 is on a distinguished road
Weird sized coupling needed - Aus
Hi everyone,
I was looking to order something like the Dumpster couplers for my machine. Only problem is they are not large enough for what I need.
I need to connect 1/2" 6TPI Acme to a Nema34 Shaft (14mm)
I could possibly get the thread lathed down to 10mm so I would only need a 14mm-10mm coupler, but I cant find anything like this either. Anyone have any ideas? (I dont want to get custom machined ones as they will be heaps expensive)
I was thinking I could just connect the 2 with tubes and clamps and then make my own version of a lovejoy on the machine once its running - Last resort really
Cheers
John
Edit: I know Mcmaster have them, but they dont ship to Aus
Old 07-28-2010, 02:15 AM
gully is on a distinguished road
Hi John
You can get those size lovejoy coupler parts from the Hubbard CNC ebay store
http://myworld.ebay.com.au/carolbrent/ just go to the store and look through their lovejoy couplers. they sell each half seperatly so you can make it to suit.
I have just purchased some through them and they were great to deal with
Gully
Old 07-28-2010, 11:59 PM
guerd87's Avatar
Perfect! Thank you very much
I was not aware that all Lovejoy couplers mate with each other, makes the range very good
They have 10mm, 14mm and spiders in stock for $14 per axis
One question: Will I need to machine my 1/2" Acme thread smooth down to 10mm to get the coupler to fit on, or will a standard 1/2" lovejoy clamp onto the thread with a simple flat ground onto it?
Old 07-29-2010, 12:13 AM
My lovejoy's turned up today, (Im going from 5/8 to 1/4). The 5/8 is nice and tight on my leadscrew and with the grubscrew done up onto the thread even without a flat spot it aint going anywhere in a hurry
Gully
Reseting of over sized tools andyhol Mori Mills 0 02-26-2010 01:52 PM
New Machine Build- Rigid Coupling Vs. Flex Coupling Johnsnd DIY-CNC Router Table Machines 10 05-30-2009 09:25 AM
Shaft coupling supplier needed - help! plain ol Bill CNC Plasma and Waterjet Machines 4 10-15-2008 04:48 PM
where can i buy spindles for diy sized machines compositepro DIY-CNC Router Table Machines 2 05-12-2006 08:17 PM
How to Ream an odd(?) sized hole MikeLMR General Metalwork Discussion 6 08-30-2004 08:09 PM
