Old 07-22-2010, 06:07 PM
HereinCS is on a distinguished road
Servo and steppers on the same machine?
I'm planning to use servos on my x-y-z axis. However, the b/c drive from doughty has steppers in them. Can I use steppers and servos together on the same machine?
Old 07-22-2010, 06:11 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
Sure can, That is how I did my lathe
Old 07-22-2010, 06:24 PM
Did you have one break out board for the servo and one for the stepper - each on a parallel port?
I don't have access to 2 parallel ports, so I'm thinking of using a smooth stepper on the servo break out board. Will that work?
Old 07-22-2010, 06:53 PM
stevespo is on a distinguished road
You shouldn't need two parallel ports, unless you need more inputs/outputs than a single can support. The servo drives take a step/direction signal, just like the steppers. The servo drive is a typically closed loop without feedback going back to the software controller.
One reason to consider a smooth stepper would be if you can't get an adequate pulse rate from Mach, due to a very high encoder count on the servo. Otherwise, there's no problem running steppers and servos from a single parallel port, single BOB, etc.
I've done this with no problems.
Steve
Old 07-22-2010, 06:55 PM
ger21's Avatar
You can't use both the parallel port and the SmoothStepper. One or the other.
Old 07-22-2010, 06:58 PM
I'm sorry for these really basic questions. Are you saying that a BOB is not specific to servo or steppers? I'll need 6 axis control and I'm not sure how to set it up. The dmm-tech package has 4 motors and a bob that controls those 4 motors. Say I get the doughty drive, which has stepper motors built in, which board do I use and how do I make it so that I won't need a second parallel port?
Old 07-22-2010, 07:15 PM
This is the only bob that has 6 axis control that I know of, will it work with the dmmtech system?
Old 07-22-2010, 07:57 PM
jsheerin's Avatar
jsheerin is on a distinguished road
C1 looks like it has 12 outputs. I'm sure others are similar.
The dmmtech link you provide has a breakout board it appears, so if you're looking to add another 2 axes of control for the steppers, I'd add another LPT port to you computer, get a C1 to connect to it along with the drives for the steppers and call it a day.
What runs smoother steppers or servo? Apples Gecko Drives 3 03-17-2008 02:59 PM
Newbie- Servo drive and steppers blackbeard52 Servo Motors and Drives 2 01-29-2008 09:24 PM
Servo driven machine, do I have to put steppers on it? Darc Mach Software (ArtSoft software) 7 12-12-2005 02:03 PM
Can Gecko's servo drives be used with steppers? bgriggs Gecko Drives 1 05-26-2005 12:39 PM
steppers or servo drives mmjpotter Gecko Drives 14 03-30-2004 02:56 PM
