Old 07-16-2010, 12:05 AM
crash5050 is on a distinguished road
Fineline Automation 3x4 r&P
Does anyone have pictures of thier machine with the table attached to it? I am devising a diabolical plan to attach too much mdf. I just want a guide.
David
Old 07-16-2010, 08:05 AM
analogman is on a distinguished road
Are you taking about attaching your CNC top or a spoilboard?
If its a spoilboard, what does your bed look like?
My is aluminum plate drilled with 1/4" NC holes every 4". I bolt the spoilboard to these holes, countersunk. I then surface the spoilboard for flatness.
Old 07-16-2010, 08:50 AM
crane550 is on a distinguished road
Do you have pictures? Not to hijack someone's thread, but I need to do this to. What bit do you use to level everything, and do you just create one bit pocket and flat it down? What about the edges of the board where the limits prevent it from reaching?
Also, how do you do your holes? This is my next step on my machine, for now I got an old peice of particle board but as far as I can tell I am off about 1/16 of an inch from one side to another.
Old 07-16-2010, 03:07 PM
Table Top
I am talking about the CNC Table top that goes under the spoilerboard. I have some trop in T nuts that I can use to bolt it on there, I am trying to decide if I need one or two pieces of MDF to make it the right height. I will have to check the bottom of my Z and see where it lands.
David
Old 07-21-2010, 04:49 PM
brtech is on a distinguished road
I think you want two layers of 3/4" MDF for a FL kit. I've talked to Nate about it. He recommended a complete sheet on the 8020 rails, with T track bolted to it, and ~8" wide strips of 3/4" MDF between the T tracks. Use 5/16 bolts that fit the 8020 slots though both layers. I think mine will be bolts in the 8020 and washers/nuts countersunk into the strips, but you can have T nuts in the 8020 and countersunk bolts on top.
An all aluminum 3x4 top would be pricey, but nice.
Old 07-21-2010, 09:45 PM
Figured it out
I spoke with Nate and he gave me that same advice. I went and bought a couple sheets of mdf and ripped them, and noticed that 6 sheets would not have gotten me close enough to the router. I have a bit of rebuilding on the Z this weekend.
David
I did get my spindle and dust collection relay problem solved....that will be awesome!
David
Nordic Automation / Eu-Automation Swemill Norwegian Club House 1 03-15-2011 07:10 AM
New Machine Build- Fineline Automation 2x4 Rack and Pinion build crash5050 DIY-CNC Router Table Machines 19 09-22-2010 05:00 PM
My Fineline 2X4 R&P Sheridan Basses Open Source CNC Machine Designs 34 03-22-2010 01:20 PM
Help with CNC automation... david_kershaw General Metalwork Discussion 7 11-06-2009 12:51 PM
Is Yeager Automation still around? dominickbox Yeager Automation 14 08-22-2007 07:49 PM
