I am upgrading the servos on my system. My previous servos had an 8mm bore and 3mm keyway. The shafts on my new servos require a 14mm bore and a 5mm keyway. I have been searching for nearly a month to find a source for pulleys. I took the current pulleys to a local machine shop but he's charging me $130 to bore out 2 pulleys and keyways. He said he didn't have a 5mm broach so I guess I would be buying that for him. I would think you could replace all the pulleys and belts for that much. I am stuck without these. Does anyone have a source for pulleys? I've checked McMaster-Carr and the typical sources. |
| http://www.cnczone.com/forums/employment_opportunity/ You are in the wrong forurm section. Post your ad under the above "forum" work and request for quote (RFQ). Someone will make you brand new ones probably for half that price. I didnt know the RFQ section of the site existed, now everything i need made i post it up there and people private message me with quotes. :P hope that helped! |
Yes people can mod yours as well, or it may be cheaper to literally make brand new ones. |
| Hello, I think you can find a lot of alternatives to having them machined if you do a Google search for timing pulleys and belts. You should be able to find some alternatives without a keyway and just use a set screw tightened on the current keyway of the shafts. Here is an example of my search and there are many more results to follow up in the search. http://robotmarketplace.com/products...elts_main.html Good luck! Do you have the capability to machine them yourself? There is also a very good source for CNC related items on eBay at the Hubbard CNC store: http://stores.ebay.com/HUBBARD-CNC-I...34Q2ec0Q2em322
__________________ Regards, Wes |
| Scobob, Stock Drive Products may have the pulleys. https://sdp-si.com/eStore/Direct.asp?GroupID=346 https://sdp-si.com/ss/PDF/78502076.pdf Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| taper lock bush.....and a pulley to suit..... 1108-14 for taper lock Pulley size you'd need to choose. Allied Electrical
__________________ Keith |
Thanks again. |
| Need Help!- Belt Drive Question about pulleys | satguy | DIY-CNC Router Table Machines | 3 | 06-14-2009 09:38 AM |
| Need Help/Advise on belt drive and pulleys | planekrazie | Linear and Rotary Motion | 2 | 03-08-2008 11:04 PM |
| Getting desparate... | Chunky | General CNC (Mill and Lathe) Control Software (NC) | 9 | 05-31-2005 10:16 PM |
| Direct Drive Servo or pulleys | sendkeys | General Metal Working Machines | 7 | 05-06-2004 08:15 AM |
| Poly pulleys vs steel pulleys | ynneb | DIY-CNC Router Table Machines | 2 | 03-09-2004 09:01 PM |
