Old 05-30-2005, 09:28 AM
Chunky is on a distinguished road
Is this the quality?
pic Saw this pic on the net of a CNC routered cavity that was cut to hold the instrument. I put in a red line to show where the cut seems to be a series of obvious straight lines rather than a continuous arc. I realize it doesn't really matter for this application, but.... on some applications I might not want that. Is this typical of what a CNC cut looks like? I'm still in the data gathering stage. Don't have a machine yet.
Old 05-30-2005, 09:57 AM
HuFlungDung's Avatar
Moderator
There are various degrees of accuracy to specify when doing cnc toolpaths. A coarse specification, with arcs broken into line segments (instead of arcs) will look like that. But a cnc can do very smooth cuts, it all depends on the quality of the data that you program into it.
Old 05-30-2005, 10:02 AM
a cnc can do very smooth cuts, it all depends on the quality of the data that you program into it That's all I needed to hear. Thanks
Plasma cut quality Apples CNC Plasma and Waterjet Machines 7 04-13-2004 09:18 AM
