Old 05-29-2005, 08:33 PM
mikejkd is on a distinguished road
Searching Ebay
What are some of the word you guys are putting in the search to find gearboxes, belt drives or long ball screws?
Old 05-29-2005, 09:09 PM
DACMACHINE is on a distinguished road
Mike
Lately there hasn't been a whole lot ballscrews and such on ebay
when searching keep it simple at first ballscrew, ball screw, leadscrew
you can always narrow down the search, ballscrew + nut etc
sometimes the people listing don't refer to the item to as belt drive or timing belt, they'll list it as a pulley
same goes for gearbox, might be listed as "10:1 reducer"
try ratio, gear box, gearbox, gear etc
good luck
Dan
Al_The_Man's Avatar
Gearboxes = Bayside
Old 05-29-2005, 10:29 PM
ger21's Avatar
make sure you add an "s" when you search. Ballscrew, ballscrews...
Old 05-29-2005, 11:20 PM
Dave's_Not_Here is on a distinguished road
Try...
... CNC
... Linear Motion
... Linear Slides
... Ball Screw(s) ... Ballscrew(s)
... Lead crew(s) ... Leadscrew
... THK (and other quality brands)
... Stepper
... Servo
... You can save your searches and be alerted of any new posts via e-mail
... If you find a seller with good stuff you are watching, save them as a favorite seller for future reviews
... Set up your searches based on most recent items posted... (saves a lot of time looking at things you already saw while looking for auctions that were placed in based on duration of auction...
Good luck... really good deals are becoming harder to find as the Hobby market continues to heat up...
Dave has left the room...
Old 05-29-2005, 11:52 PM
murphy625 is on a distinguished road
You ebay guys must spend hours searching...
Copy and paste the code below into the search bar just as it is with all brackets.
(Ballscrew*, ball screw*, lead screw*, leadscrew*) -point -pen
(gear box*, gearbox*, reducer*)
Use the ( and ) to enclose entire search strings seperate by commas. Use the * to denote wild card character..
Searching for Gear Reducer will not return Gear Reducers.. On the other hand, searching for a Gear reducers will not always return the Gear Reducer.. Thus, we use a wildcard character..
Use the - to reject anything with that word..
Good luck.
Murphy
Old 05-30-2005, 07:36 AM
Gold Member
JFettig is on a distinguished road
I have been searching:
servo
thk
ballscrew
ball screw
encoder
and more, sometimes I search within the description, a little check box. If I see something that comes up a lot that I dont want in my search I put something like this:
-mityuto
which comes up a lot in my encoder searches within the description.
lots of people selling these kind of things add stuff like cnc and ballscrew and stuff like that to the title just to get more hits.
Jon
Thought on Design found on Ebay dfranks DIY-CNC Router Table Machines 17 10-11-2007 02:32 PM
Ebay# 3855421933, FRAUD DYNA MYTE MILL davidponte CNCzone Club House 20 07-01-2005 08:09 AM
CNC mini lathe on ebay TinkerDJ Mini Lathe 2 01-16-2005 08:36 AM
Ball screws on eBay with no specs WoodSnarfer DIY-CNC Router Table Machines 10 11-15-2004 09:19 AM
NEW ebay links!! CNCadmin CNCzone Club House 2 07-10-2004 07:22 AM
