Old 05-29-2005, 12:32 PM
Edh Edh is offline
Edh is on a distinguished road
Panel Saw type CNC?
I would like to build a 4'x8' (+) area CNC machine to cut plywood & foam. Due to some space restrictions, I was thinking of building it simalar to a panel saw to minimize floor space.
[Note -a panel saw is a (almost) vertical saw like they use at Home Depot for custom cut wood - See Photos Here ]
Has anyone done this? Other than making sure motors are strong enough and there are no gravity held bearings, can you think of anything else I would need to consider?
My plan would be to build it as a normal horizontal table, then build a vertical mount/table for it once I had it working.
Thanks,
-Ed
Old 05-29-2005, 12:50 PM
ViperTX is on a distinguished road
Can you imagine what would happen when you powered it down? It would definitely be a way to preload the bearings.
If space is a consideration.....figure out a way to change from horizontal to vertical for storage.
Old 05-29-2005, 12:56 PM
Al_The_Man's Avatar
I would think that you would need to put a counter-balance system on it, without power to the axis it would remain wherever you manually positioned it.
Old 05-29-2005, 01:19 PM
chuckknigh's Avatar
Gold Member
chuckknigh is on a distinguished road
Home depot uses a series of ACME bricks (the kind with the 3 holes through them) to act as a counterbalance to the skil saw. They run a steel cable straight up, along with the power cords, and over a pulley at the top. Optionally, a torsion spring could probably act as a counterbalance, too...but nowhere near as cheaply.
I had a similar idea, a while back, before I decided I needed small routers, instead of 1 really big one.
-- Chuck Knight
Old 05-29-2005, 01:21 PM
OCNC is on a distinguished road
Originally Posted by Edh
Thanks,
-Ed
Check out www.otocoup.com . This unit is stored against a wall but might also be usable that way with the addition of a counter-balance and some creative material hold-downs.
Chris
Old 05-29-2005, 02:47 PM
LeeWay's Avatar
LeeWay is on a distinguished road
Personally, I think it would need to be operated horozontally as well. You would have to have one really complex holding system on the vertical if you were wanting to make multiple cuts in a sheet. I also feel that it would have to be one heck of a machine to outdo an experieced panel saw operator. Don't judge by the guys you see at HD using these saws. I have cut at least two truck loads of MDF on a panel saw and you get quite good and fast. Since it is all straight cutting to be done on a panel saw, is there really a benefit to CNCing it?
Lee
Old 05-29-2005, 04:28 PM
skippy is on a distinguished road
Leeway, I think he means building a router but (in his words) "building it similar to a panel saw to minimize floor space".
Old 05-29-2005, 06:59 PM
ger21's Avatar
I've seen a commercial machine like this, but can't find the link right now. If I find it, I'll post it.
Old 05-29-2005, 08:18 PM
bkukowski's Avatar
bkukowski is on a distinguished road
if it is operated vertically, and pieces are cut all the way through, i'd be concerned of them falling and hitting the router. Also, it would take much more force to secure your pieces vertically. it would be interesting to see it done though.
router finally being built!
y axis done!
hobbycnc controller done!
...mounting nsk rails and thk rail. aligning leadscrews
Old 05-29-2005, 10:27 PM
ger21's Avatar
No, it would be the same. There is a lot more force on a part being cut than gravity. Unless your cutting 100 lb parts.
  #11   Ban this user!
Old 05-29-2005, 11:09 PM
jderou is on a distinguished road
I would just make sure the gantry runs from left to right, instead of up and down. That being said I dont think their is an issue with counterbalancing the router moving up and down, we do this with our z axis on standard routers dont we? It must be screw driven, though. If you would use a gear drive you could do some damage when you turn the power off.
Actually I think its a pretty good idea. You could put rollers on the bottom (liek a conveyor) to make it easy to load large panels, plus dust falls to the bottom.
  #12   Ban this user!
Old 05-30-2005, 09:05 AM
LeeWay's Avatar
Thanks Skippy. I realized that after I looked at Chris's link above. A router makes a lot more sense then a simple straight line panel saw.
Lee
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 12:06 AM
Making money with CNC Johnuk CNCzone Club House 26 12-13-2009 10:46 AM
Fanuc CNC controler zekk_2 Servo Motors and Drives 19 02-27-2008 01:46 AM
The start of a big CNC project... UKRobotics General Metal Working Machines 10 09-30-2004 05:34 PM
CNC Operator Panel Design Al_The_Man DIY-CNC Router Table Machines 17 09-13-2004 12:03 PM
