Old 05-29-2005, 06:29 AM
hpghost is on a distinguished road
dremel tool
which tool do you use to cut wood with your dremel fixed on the cnc?
Old 05-29-2005, 08:52 AM
debogus's Avatar
debogus is on a distinguished road
Dremel has a hss 2flute wood router bit that work ,ok (3/16 )
Also carbide depot has 1/8 shaft / end mills , lots of sizes ( 1/8 down to micro)not for wood , but work good for most things.
The only bits they list for wood are 1/4"
Havent tried the "sprial cut" bit that came with the dremel yet .( its to long for my set up ,perhaps cut it down)
Dave
HELP Tool changer problems ddprecision Haas Mills 9 01-14-2011 04:24 PM
mazak v5/fanuc 6mb tool changer mastercam post edit wild01 Post Processor Files 1 10-26-2006 08:44 AM
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 07:51 PM
Miniature Automatic Tool Changer 1ctoolfool Product Announcements & Manufacturer News 1 04-18-2005 05:56 AM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 08:56 AM
