Old 07-08-2010, 07:37 PM
aledford is on a distinguished road
Using CRS as a bearing way
I've seen a lot of people using 1/4" CRS on top of 8020 as a bearing way. This is what I am planning to do on my new build. In all the builds I have seen, the CRS is attached with 5/16 carriage bolts mounted with the head in the slot and the steel bolted on with a hex nut. My question is could you drill and countersink the CRS and attach with flat head screw that would be screwed into T-nuts in the 8020 channel. Would this affect the strength or accuracy of the way. I think this would make for a cleaner looking build
Thanks for any info
Alton
Old 07-09-2010, 08:28 AM
jsheerin's Avatar
jsheerin is on a distinguished road
You could, but if you used the 80/20 nuts, it would be way more expensive. Also, your holes would have to be placed more precisely. I'm not sure about others, but I drilled 3/8" holes for 5/16" bolts, and that gave me a little wiggle room when mounting the CRS rails. Then you can use calipers to tweak the CRS in so the edge is parallel to the edge of the 80/20 while you tighten the nuts down on the carriage bolts.
Old 07-12-2010, 02:36 AM
domar is on a distinguished road
crs rails
Hi I am also looking at using crs for my rails. The problem with using csk screws ia that they self centre on the csk so you need to be spot on with your location. I will not be using 8020 just 50mm square aluminium tubing and I plan on using button head socket screws to mount it. This will give quite a neat appearance and no protrusions to catch on things.
Regards
domar
Old 07-12-2010, 02:46 AM
leaveme is on a distinguished road
It looks interesting to me.
Do you have a picture of that...I would like to see how it looks.
Old 07-14-2010, 11:35 PM
metalworkz's Avatar
metalworkz is on a distinguished road
You could also counterbore the mounting holes for either a button head or perhaps a socket head which will bring the heads down flush or almost flush with the ways and still provide some adjustment for the final fitting.
Regards,
Wes
vxb bearing co oldhack Linear and Rotary Motion 3 09-05-2009 12:23 PM
Bearing help Bri4n JGRO Router Table Design 6 07-22-2009 06:26 AM
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
Bearing sala84 JGRO Router Table Design 7 11-03-2006 09:42 AM
Bearing in MDF Photon DIY-CNC Router Table Machines 6 05-20-2004 04:18 PM
