Old 07-07-2010, 06:56 PM
nishantpol is on a distinguished road
motor control chips
I am designing my own electronics for use with DC motors and encoders for a CNC router. I bought a tle 5205 (Infineon, Jameco 1627518) and hooked it up to a PSU, using a breadboard as the medium and a voltmeter between the two outputs. However, regardless of the input pin states, the voltmeter always read the same. In fact, when I hooked up the voltmeter to the inputs and compared them with ground, it read 3V. All the other parts in my electrical design work fine. Can anyone suggest a solution to this problem or offer a better chip that will drive a 12V motor using step and direction signals?
Thanks,
Nishant
Old 07-07-2010, 09:55 PM
MarshaJ847 is on a distinguished road
My first guess would be that the Open Load detection circuit is operating, i.e. the meter isn't providing the load of a real motor so the circuit is protecting the chip.
Old 07-08-2010, 03:37 PM
Thanks! Working now
This time, I soldered all the wires directly to the chip and used a motor between the outputs. I had the input lines free floating before (not attached to the PSU 5V line nor ground. When I connected the inputs to ground, (the chip control is active low) the motor whirred about.
Thanks so much.
Nishant
DC motor control for 180v dc motor, will this work ? carl0s General Electronics Discussion 2 04-14-2010 07:31 PM
Cards Support Stepper Motor Driver Control & AC Servo Control. Johnnyatcnc Product Announcements & Manufacturer News 0 04-09-2010 03:57 AM
Allegro 5804 IC stepper motor translator/driver chips wanted Mervyn Mitchell Want To Buy...Need help! 0 04-05-2010 05:18 AM
haas motor controle board chips Shide Stepper Motors and Drives 1 03-01-2006 04:37 PM
Cook your chips to make more chips :) ToMMY2ooo Bending, Forging,Extrusion... 3 09-07-2004 01:38 PM
