Old 05-27-2005, 09:20 AM
abasir's Avatar
abasir is on a distinguished road
Conversion cheap manual milling table to CNC
The original table had very significant backlash and very difficult to move due to the way the leadscrew is attached to the 'holding' plate. I decided to capture the leadscrew using two skate bearings and flexible coupler. No noticeable backlash now, very smooth move eventhough the 8TPI leadscrew is directly coupled to the stepper (2.3V @ 1.75A - 6wires)
Photos below... all done in one afternoon...
ID:	7878   Click image for larger version
ID:	7879   Click image for larger version
ID:	7880   Click image for larger version
Stupid questions make me smarter...
See how smart I've become at www.9w2bsr.com ;-P
Old 05-27-2005, 01:27 PM
H500 is on a distinguished road
How did you eliminate the backlash between the lead screw and the nut?
Old 05-27-2005, 05:59 PM
abasir's Avatar
The original leadscrew and nut had no noticeable backlash. The main cause for significant system backlash was from the way the leadscrew was attached to the table.
If you can see in the picture #1, the original leadscrew was attached to the table using a metal plate. One the thread side, it had a dowel(?) pin and the other side was the handle. If you press the handle very tight against the plate, backlash is zero BUT it is almost impossible to turn.
BTW, I'm yet to get a dial gauge to measure but if backlash is still unmanageable, I'll try potting it using 'Milliput' epoxy to see how it goes
Old 06-21-2005, 11:33 PM
abasir's Avatar
The final setup...
ID:	8314   Click image for larger version
Old 06-22-2005, 09:10 AM
rippersoft is on a distinguished road
Very brilliant stuff!! I had wondered if someone would/could/did a conversion like this. What is the torque rating for the stepper motors?
Old 06-22-2005, 09:46 PM
abasir's Avatar
Motors are from scrap dot matrix printers... rated: 4.2V @1.75A, I would guest somewhere around 100-120oz/in.
Old 06-30-2005, 01:33 AM
yukonho is on a distinguished road
Any word on how well this is working?
colin
Old 06-30-2005, 08:00 PM
abasir's Avatar
It's working fine.
Have not tried aluminum milling but MDF and acrylic cut with no problem. Backlash is about 0.002" in both X and Y axis but that's something I can live with
Currently, I could rapid to about 50ipm with no loss step.
Sieg X3 Milling Machine CNC Conversion Project Bird_E Vertical Mill, Lathe Project Log 21 11-30-2009 10:31 AM
Manual lathe CNC conversion kong General Metal Working Machines 10 08-20-2005 03:56 PM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 02:43 PM
CNC Drill driving the milling table Com Vertical Mill, Lathe Project Log 2 04-04-2005 03:27 PM
Manual EDM to CNC conversion Jim Estes CNC Plasma and Waterjet Machines 13 03-15-2005 07:06 AM
