Old 05-26-2005, 05:49 PM
diogee02 is on a distinguished road
Exclamation Question on Bit Sizes????
Hi all;
I am pondering the idea of building a cnc router table. What is the smallest bit size that I can use to cut 1/8" balsa and maybe 1/16". I am going to use this table to make dollhouse parts and model plane parts since a laser cutter is probably going to be more expensive than building my workshop. Me being a cheapskate would be my secondary answer.
Thanks for any input.
Old 05-27-2005, 04:13 AM
Gold Member
CRFultz is on a distinguished road
For small detail, i use a .0313 fishtail cutter on 1/8th material. For regular work i use a .0625 router bit or a 1/8th 2 flute end mill.
Cutter sizes are available from really small on up so what you choose to use would depend on the detail you want the cutout piece to have. 1/8th is a good common tool for me.
Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
Old 06-02-2005, 05:43 PM
CNCRob's Avatar
Moderator
CNCRob is on a distinguished road
For 1/16" balsa I have had good luck with regular .050" endmills.
Old 06-02-2005, 07:22 PM
strat's Avatar
strat is on a distinguished road
grizzly tools and i think harbor frieght have sets of micro bits the price is fare and wanna talk about tiny cuts it blew my mind the first time i used em their so tiny you just have to make sure your not trying to cut to deep in one pass or snap...... i think the shaft on em were 1/8 so if you router has a collet for em no prob i use them for when i dont wanna waste alot of material or need real small cuts when i have to move alot of stuff i use up to 1/2 in and i also use carbide router bits
Multi Bit Drill Head smythe WoodWorking 0 11-16-2004 12:02 PM
End Mill Bit Supplier? UCFMems General Metalwork Discussion 3 08-11-2004 02:21 PM
Spindle Speed & Feed Rates - Question Moondog DIY-CNC Router Table Machines 1 07-23-2004 06:24 PM
Router bit feed rates. ynneb DIY-CNC Router Table Machines 3 05-28-2004 11:54 AM
Multiple Bit Hobby CNC Router, Possible? Sanghera DIY-CNC Router Table Machines 27 04-17-2004 12:20 AM
