I've been browsing and trying to learn from everyone here for about 3 years. Finally, I'm getting started. My goal is a 3 axis, very precise machine that will cut mainly wood, but occasional aluminum as well. I'm borrowing lots of ideas from everyone else's builds, but I won't pretend to know what I'm doing. It's going to be slow progress as I get the parts in. I do have a machinist friend who hopefully can help me with some parts. I'd truly appreciate some, any, advice. Please also let me know if I'm about to make a big mistake. My design goal is to have a machine that has a work area of 4 feet by 2 feet. Precision is important so I went with the nicest sets of slides that I can afford. Items in hand: 1. THK ball screw with a thread length of 44", travels around 42" with a .2 pitch. I bought this several years back, it's go a bit of tarnish, but looks close to new. Not quite 4 feet, but close enough. 2. I have 2 sets of THK SR25 rails that I'll cut to length. They are used, but are in good shape once I polish of the tarnish. 3. I have these two slides coming from ebay: http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_6875wt_911 for the y axis http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_6875wt_911 for the x axis. Anyone have any thoughts on these? 4. I have a Bosch motor mount from K2. Once I have the Parker Daedals in, I'll be working on the frame. Thanks ahead for the comments and advices. |
| On a moving gantry design the space that the gantry occupies in the X axis (long axis) will limit your 42" travel to something less than that. Similarly, the space that the Z axis assembly occupies in the Y axis (shorter axis) will reduce the actual travel in that direction. Your 42" travel can become closer to 36" in in actual practice. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
instead of X axis? We made a router out of similar actuators; it works pretty well. We made a frame out of heavy steel tube to support ours; what's your plan? One thing you might have to deal with is the weight of your router causing the Z axis to drop when power is cut. We tried using constant-force springs to counteract that, but they don't last long; gas struts are probably a better bet. The actuators are good at keeping dust out of the ballscrews and slides; are you going to make a bellows for the X axis? If those are stepper motors on the ebay actuators, then it won't be hard to drive them; if they are servos then you need to figure out what sort they are. Some are easy to deal with, others are nearly impossible... Andrew Werby www.computersculpture.com |
Limit switch actuating points will need to be considered in calculating the total travels also. You can start with the actual travel that you must have and add to it to arrive at the lead screw length that is needed, or you can start with the lead screw length that you have on hand and calculate the travel that you will end up with. These are the two main concepts. You can design a narrow Z axis assembly, and a narrow carriage for the gantry to minimize the loss of travel with the lead screws that you already have. Try not to add anything else that will restrict the total travel in any way. CarveOne
The Daedals are meant to work together. The shorter one obviously mounts onto the longer one and the width is less than that of the trucks. I should be able to get 20" of cut, don't you think? I have not paid for them yet, so please advise. |
An alternative, is to buy a set of x screws from LM2008 and do two screws on the x axis. But I want this machine real tight, and I'm not sure if Chai's screws are of that quality. |
#10
Got my 203v. I hope they are as tough as their claim, I'm surely going to be the first to blow them up .I plan to use them with this board http://www.cnc4pc.com/Store/osc/prod...products_id=46 this jogger http://www.cnc4pc.com/Store/osc/prod...roducts_id=162 this power supply http://kelinginc.net/KL_6515.pdf If I'm sounding like an idiot with the mechanical parts, I'm retarded when it comes to the electronic parts. I have another friend who is handier (and hopefully be bribed with the tons of excess rails that I've collected) who'll hopefully keep me from burning down our house. Are my choices reasonable? Do I need anything else? I saw on candcnc.com that they connect the driver to some sort of serial plug so that I can just plug the motor in without having to wire it to the geckos. How did they do this. And is their break out board any better? |
#11
| The choices look good to me. I'm using four G203V (dual X axis motors), C11G, Keling 72vdc 20A PS, and four Keling 495 oz steppers. Works really nice together. The 72vdc PS is the max safe voltage option for the G203V. 65v is used by a lot of folks and the only tradeoff is a little less motor speed and torque. CarveOne
#12
I use the same BOB and Power supply on my machine. Both work great, I have servos though so I use the G320s. I'd skip the expensive MPG, not needed. I would go for a wireless xbox controller or shuttle pro controller, or something alot less expensive, that has more features than just jogging. Also you need to use another Parallel port for it. so more cost again. |
| 5 years later | extremetalon | Canadian Club House | 3 | 04-27-2010 04:17 PM |
| 20 years out of NC New to cnczone | RIPPINANDRUNNIN | CNCzone Club House | 0 | 06-21-2009 01:42 PM |
| New to Forum but done CNC for years | rfrenzl | Benchtop Machines | 8 | 07-14-2008 05:13 PM |
| Are old mills around 23 years always a bad buy? | Smertrios | General Metal Working Machines | 19 | 09-06-2006 04:35 PM |
| After all these years | Jim Estes | Moldmaking | 1 | 03-02-2005 12:54 AM |
