Please take a look at my z axis. Unless I mount the motor way low, there is very little available cut depth. Just a couple of questions: 1. Should I take the brakes off to give more cut depth? 2. Or should I mount the motor an inch or so lower? Will it torque the z axis too much? 3. Should I just buy a shorter z axis? |
| It looks like your motor is mounted at the bottom of your z-axis. Is that true? I don't think I've seen another machine like that. Most mount the motor at the top, not the bottom.
__________________ Bob "Bad decisions make good stories." |
| Place an offset plate between the trucks/carrage and the motor mount ??? Wayne |
That's what I'm thinking as well. If I do so, I can lower the entire router assembly down past the brake. I just wonder though, if this would cause too much torque on the y axis. I'm leaning towards picking up a k2 slide. Only thing I don't like is that it uses a leadscrew rather than a ball screw. |
| Waynee is right.. In commercial routers and all DIY routers the Offset plate is installed.. Just make one from MDF and test run..If it works right then for rigidity make one from Aluminum...
__________________ http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/ http://my-diysolarwind.blogspot.com/ |
__________________ Deeds not words... VoltsAndBolts Alternative Power Forums http://www.voltsandboltsonline.com/ |
| Does anyone here resurface there own Disc or Drum brakes? | slashmaster | General Metalwork Discussion | 6 | 05-21-2009 04:03 PM |
| CNC BRAKES OPERATORS WANTED IN NJ! | CNCBRAKESWANTED | Employment Opportunity | 0 | 12-20-2007 02:05 PM |
| Brakes | meghanath | Mechanical Calculations/Engineering Design | 6 | 10-12-2006 08:04 AM |
| Servo's with brakes ? how important | curtisturner | Servo Motors and Drives | 3 | 09-01-2006 09:29 PM |
| Brakes on steppers | JerryFlyGuy | General Electronics Discussion | 7 | 03-29-2006 09:09 AM |
