Old 06-24-2010, 02:33 PM
SatanKlawz is on a distinguished road
Setting up G540 with mach 3
It was late last night when I got my pc up and going with mach 3. I set my parallel port to the correct setting in the bios. I am now wondering what I need to do with that file that is provided for mach 3 to work with the g540 and is there anything else I need to do besides plug it in and start mach 3?
Old 06-24-2010, 03:04 PM
awerby is on a distinguished road
The XML file?
Just put it in the Mach3 folder; it should show up as a "profile" in Mach Loader. Choose that when you start up and see if it works.
Andrew Werby
www.computersculpture.com
Old 06-24-2010, 03:12 PM
brtech is on a distinguished road
I just did this yesterday.
You copy the xml as directed. Start the loader, and you will see it.
You must put the E-Stop circuit in place (or at least connect a wire between the E-stop input and ground). You don't need the home/limit switches to get something to move.
It "just works" after that, although you will need to put your own values for the steps and such, which depend on your drive components.
Old 06-24-2010, 06:42 PM
MOTHER F'ER!!!!!! My db25 cable is M to F and I need a double F..... off to frys tomorrow on lunch break to get an adapter.......... I cant wait any longer!!!!!!
Need Help!- G540 PWM Mach settings skidiiii Gecko Drives 17 05-16-2010 08:14 PM
Newbie Setting Up His G540 phil m Gecko Drives 26 02-23-2010 04:14 AM
X2 - Electrical questions - Setting up Geco G540 with the X2 CNC74 Benchtop Machines 9 02-03-2010 09:51 PM
do you know if the g540 uses the gecko setting? draughted LinuxCNC (formerly EMC2) 15 10-06-2009 01:37 AM
Setting up the G540 boxwood Gecko Drives 4 09-15-2008 12:44 PM
