I want to use delrin as sliding guides for my Z axe and 5/16'' steel rod but if I use a 5/16'' drill bit to drill the hole in the delrin, it's way too tight, next drill bit size and it's way too loose, how do you guys do it? Is there a drill bit size between 5/16'' and 21/64'' ? Thanks, Marc.. |
| I think you need to use a reamer.
Marc.. |
| A reamer is a device for creating a close tolerence hole. Drill bits aren't very good about keeping diameters better then +/- 1/64. Go to www.mcmaster.com and search the term reamer. They aren't too expensive for a standard size like that.
__________________ Proud owner of a Series II Bridgeport. |
| With 5/16 being .3125", the next size up is an 8mm (.3150") after that is a letter O drill (.3160"). Do you have a dial caliper available to measure the inside diameter of your block. Delrin does have some springiness to it and will "retract" when you drill thru it. Measure your hole, subtract .3125 from it. Take the difference and subrtact it from the .3150. If that new figure is at or slightly over .3125 you should be ok. Then drill it out with the new bit.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
Thanks all Marc.. |
| Turning Delrin | CNCadmin | Glass, Plastic and Stone | 3 | 11-15-2006 05:32 AM |
| Has anyone tried this stuff (type of delrin) | dmoore764 | DIY-CNC Router Table Machines | 10 | 03-17-2005 09:58 AM |
| Delrin T Linear Guide Systems | Moondog | DIY-CNC Router Table Machines | 10 | 07-05-2004 08:02 PM |
| Delrin nuts for lathe? | kong | General Metal Working Machines | 5 | 04-23-2004 07:26 AM |
| Uhmw Or Delrin Or Nylon For Antibacklash Nut? | ljoe1969 | DIY-CNC Router Table Machines | 4 | 11-19-2003 03:39 PM |
